Question about Dishwashers
Asko dishwasher trips safety switch when turned on
  • ianstokes Apr 19, 2008
    Wire rubbed through on rh lower door opening as suggested,what a **** design !! Plastic coated power cables rubbing against stainless steel edge every time the door is opened and closed.. UNBELIEVABLE !!! Thanks heaps ..
    Sergeant:
  • 351 Answers
Dont know what model you have but check to see if theres a broken wire in the door right side bottom,check the element or the wax motor red right side top in door if your model has a drying fan.if this doesnt help i will need to know your model no
Posted on Apr 09, 2008
Asko dishwasher D1760 tripped the power on drain function, replaced drain pump then worked ok. Next day dishwasher started making a very loud noise when washing then tripped power. Thoughts?
The replacement pump may have failed early on. Something other than the pump may causing failure, such as ingestion of some kind of destructive material.
Feb 11, 2017 | Asko Dishwashers
Asko d1756 power trips when door is closed
The switch in the door may have a bare wire touching the sides causing a short. Check a schematic for the proper way to remove and test the switch. Look for bare wires or any insulation cracks.
Mar 15, 2014 | Dishwashers
My Asko dishwasher has tripped the overflow switch. We have tilted the machine and let it dry out but the pump still continues to pump and the machine will not switch off unless at the mains. Is there a...
Not sure about this brand or if this will help but.... if you are talking about the machine stopping before cycle is done, make sure you are using automatic dishwasher detergent, (yes, I know this is a stupid statement but......., and that there is no regular dish soap on any items being washed . I had a husband at one time that thought the soaps were interchangeable and the bubbles tripped the overflow switch, (ours had a "float" instead of switch), we had a mess.
Aug 18, 2013 | Asko 24 in. D3250 Built-in Dishwasher
Dishwasher won't turn on trips safety switch
This dishwasher has a serious electrical fault that caused the safety switch to trip.
You need this to be repaired by a qualified repairer.
Apr 12, 2013 | Miele 23 in. Novotronic G841 Built-In...
D1976 machine won't do anything but pump out.
The flood switch must have tripped. This is likely to happen if there is a water leakage.
If you can pull the dishwasher out (after turning off the power and water connections) and tilt it on one side. Wait a little (to let the switch dry up) and then turn it on.
Hope this helps.
Jun 17, 2011 | Asko D1976 Built-in Dishwasher
Asko D3230 dishwasher pump will not turn off, with main switch on
This is a anti flood activation. It is a safety device (polystireen float and micro switch at the base of the washer) that keeps the drain motor running due to water leak / spill detection. Dry the water and rectify the leak (normaly pipe or clamp leak) and this should solve the problem.
Mar 26, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Asko D3122 dishwasher will not fill with water and will not turn off
you may have water under the dishwaher ... have any plumbing work done lately?
if the dishwaher overflows or leaks it will trip a float switch under the dishwasher... as long as it is triped it will run the drain pump.. and not let any water into the tub...
the water will have to be removed and the leak stopped before it will run a cycle....
Hope this helps if not let me know more about your problem..
Mar 20, 2009 | Asko D1876 Dishwasher
DW trips cicuit breaker
I have seen a lot of these older dishwasher break the wires running up to the timer. the break right near the bottom of the door where they flex when you open and close it. I would turn of the power, remove all the torx screws along the inside edges of the door, as well as the 2 on the bottom edge of the door facing up (you cant see them, just gotta feel around for them) and loosen the 2 on the top of the door near the latch ( so you can tilt the control panel out to remove the outer door) follow the wires from the timer down to the bottom of the door and see if any are broken or missing insulation. If not, take the bottom panel of the dishwasher as well and locate the 2 terminals hooked to the heater and check them with an ohmeter to see if they are grounded to the frame of the dishwasher. the dishwasher may be doing a heated rinse just before the dry cycle even though you have low temperature and no heated dry selected, so the problem may still be the heater. Good Luck!
Dec 12, 2006 | Asko 1385 Dishwasher
Dishwashers Logo
113 people viewed this question
Top Dishwashers Experts
