Question about Refrigerators
Freezer works but refrigerators doesn't
Freezer works but refrigerator part doesn't. what part do I need and is it easy to install
  • Refrigerators Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorFreezer works but refrigerators doesn't - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 04, 2010
How can i get my refrigerator to start cooling again
You need a new defrost coil. they are easy to install but you will need a heat gun or hair dryer to defrost your freezer coils.
Aug 24, 2014 | Miele KF1911SF Bottom Freezer French Door...
Hat is wrong with my armana refrigerator when the top half doesn't get cold
check the fan inside the fridge, if it's OK, you have to refill with gas
Mar 24, 2013 | Refrigerators
I have a Kenmore refrigerator 795690002900 bottom freezer. The freezer is working but the fridge doesn`t work. The temp adjustment for freezer lits up the 6 and 7 will not adjust, the fridge part does not...
Mine bottom freezer 10 or so year old unit did the same thing, problem was the thermal switch ("clicks on") on de-ice circuit was broken. Quick "fix" is to defrost the unit by shutting it off, putting frozen food in a cooler. Once the ice melts the path for blowing cold air UP to the frige will be opened. Will work fine for days until the freezer ices up again.
Most likely the "clicks on" or thermal swithch that is bad and will not let the defroster heater work. Easy fix. Everything is BEHIND the pull out frozen food tray. Remove a couple of screws and you will see all the ice. If I remember correctly my clicks on was just to the right of center and took only 5 minutes to replace after defrosting the unit.
Hope this helped,
Ken C
Apr 30, 2012 | Kenmore 71279 Bottom Freezer Refrigerator
The freezer is working but the fridge part isn't
this is usually do to a blockage in the air duct from the freezer to the fridge. put food in a cooler with ice and unplug and open all doors for 12 hours. If doesn't work, need a repair man due to fan probably broken
Nov 03, 2011 | Amana AFD2535FE Bottom Freezer French Door...
Freezer side works fine, Refrigerator side is too warm
Hello.
The leading problem when freezer works yet the refrig. section doesn't get cold is going to a problem with a automatic defrost system defect. Do ya see a bunch of frost inside of the freezer on the back wall?? if yes ya do see that frost build up ist defiently not defrosting and this tip i wrote covers what to check when it doesn't defrost http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Oct 04, 2011 | Jenn-Air JCD2389G Side by Side...
My jcd2389des freezer is working fine but the refrigerator isn't cooling properly
Hello Sharleen,
GENE
Oct 03, 2011 | Jenn-Air JCD2389G Side by Side...
Maytag mtb2156ge refrig freezer not working..Refrid cool but not real cold. Freezer fan doesn't appear to be working. Does that affect fridge coldness too?
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 07, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Freezer works/ refridgerator doesn't cool
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Refrigerators
Freezer works great but refrigerator. Doesn't get cold its cool but not cold turned thermostat to 33 and ut isn't gettingcold
heatman101
Aug 21, 2011 | Kenmore Side by Side Refrigerator
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
