Question about HP Photosmart Premium C309A All-In-One Printer
My printer quit working. When I plug the wire
My printer quit working. When I plug the wire from the adapter to the printer in, the green light on the adapter goes off. What on earth?
Patti
    Scholar:
  • 53 Answers
Connect the Printer Directly to the Wall socket.
Then Perform the steps given below to reset the printer.
This will remove all the network and fax settings.
if the issue still persists, contact HP for replacement.
Please remove the power cable from the back of the printer.
Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
We have to press the keys on the printer. Release the buttons as soon as the power cable gets inserted to the printer.
Posted on Jun 02, 2010
Testimonial: "Did what you said, had tried all but the #&6 simultaneously. Still won't work. Guess I'll talk to HP. Thank you. "
I dont know wher to connect the wires from my speakers
The light green is the speaker connector. Both on sound card and speaker adapter. Not sure what the others are, based on details given.
Aug 30, 2012 | Creative Labs Sound Blaster Audigy 2 Sound...
I have an HP power adapter 0957-2269 for an HP Deskjet D1660 printer which has stopped powering the printer. when the adapter is plugged into the mains, a green light comes on but when the adapter is
Check eBay for replacement parts. Voltage, power capacity and the connector can all vary but you can probably find a replacement part. If not, the things are so cheap these days.
I knew a consultant who did training. In every city he would buy a new inkjet at the start of his courses. At the end of his courses he would leave the printer in the room as a tip for the hotel staff.
Aug 08, 2012 | HEWLETT-PACKARD Hewlett Packard Hp...
The printer is plugged in but does not turn on. The green light on the AC adaptor is on. I have tried a friend's AC adaptor and it did not work either.
I think it would be wrong to suspect a problem with the adapter wire if the same problem occurs with two adapters. Do both adapters work with your friends printer? If so one would suspect that the plug port on your printer is defective.
This is the advice from the manual:
Power button is not lit
1 Disconnect the power supply cord from the wall outlet, and then from the printer.
2 Plug the cord all the way into the power supply port on the printer. make sure it is well seated
3 Plug the cord into an electrical outlet that other electrical devices have been using.
4 If the Power button light is not on, press Power.
If this does not correct the problem and it is a new purchase I would consider returning it to the vendor. Otherwise you may need to have a technician Tto investigate and confirn that power is reaching the printerre and the problem lis elesewhere with a switch or posisbly you need to replace the power connector port on the printer.
Dec 11, 2010 | Lexmark X8350 All-In-One InkJet Printer
Printer is dead
Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Leave the other end of the power cord attached to the power outlet. Bypass any surge device or power strip, plug the power cord straight to the power outlet in the wall. Properly secure the power cord in the power adapter. There should be green LED light on on the power adapter. Plug the power adapter back in the printer. Make sure it's plugged in securely and in the correct position. If it won't power on automatically, press the power button. If that doesn't help, it may be a hardware problem. If that's the case, I suggest you contact Lexmark Technical Support to further investigate the problem.
Jul 15, 2010 | Lexmark X2600 InkJet Printer
I have a Dell M20 and it has stopped turning on. the green light on the adapter is illuminated when plugged into the wall ... then when plugged into the power port on the M20 the green light goes out. ...
I want to say that it sounds like a short in the wires for the adapter. I doubt that a motherboard would cause the light to go out on the adapter. Go to best buy, frys, or some computer store and ask them to let you plug your laptop in to test and see if it is the wire. They surely have a dell being displayed and usually they will let you plug it in with that wire to see if it works.
Dec 27, 2009 | Dell Precision M20 Notebook
NO RESPONCE-NOTHING - DEAD - CHECKED WIRES -KODAK ESP-3-WAS WORKING FINE, JUST QUIT.
take power cable and usb cable out of the printer .hold down the on/off button for 40 seconds without cables. then plug power cable and restart ur printer. make sure the green light on end of power cable is on. contact kodak @ 1800 421 6699 for further issues
Jul 26, 2009 | Kodak Office Equipment & Supplies
On the issue with th ebattery on the 1521 inspiron. Took battery out and plugged in still will not power up. Could it be the adapter as well?
On the ac adaptor, look for a green light that will turn on when you plug it into the wall outlet, if its on that means the ac adapter working. If you get a green light on the ac adapter but then the green light goes away when you plug it into the laptop then that means the laptop has a bad motherboard.
If you plug the ac adapter into a wall outlet and get no green light then that means the ac adapter is bad and you would need to get another one.
Jun 21, 2009 | Dell Inspiron E1705 Notebook
HP ac/dc adapter 0950-4340
Hi , plug first the adapter to printer before plug it to ac outlet.
Feb 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Photosmart Premium C309A  All-In-One Printer Logo
235 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
