Question about Honeywell HS-300 16'' Stand (Pedestal) Fan
Need a new fan blade for honeywell HS-300 16" standing fan
issy2
  • 460 Answers
SOURCE: Blade for Patton Stand Fan Model 1010-MP1
does it have a slight bend or a worst one.. generally these blades are quiet to replace... please tell us where u stay...
Posted on Sep 09, 2008
red54eyejp
  • 25 Answers
SOURCE: blade broke where to get new one
You can call by phone Lasko customer Service and Replacement Parts......1-800-233-0268.......givi them FAN info and they will ship you part..........................Also check, your product may be covered under WARRENTY or may be listed under product recall .......either will reduce your COST .....
Posted on May 11, 2009
  • 3600 Answers
SOURCE: I have a Honeywell Black 16
The button on front of the fan unscrews counter clcokwise then pull the fan off the shaft.
Posted on Sep 27, 2009
Testimonial: "Gave very speedy help that resolved my problem! Thanks avid."
ftw1952
  • 10319 Answers
SOURCE: I have a Honeywell 16"
remove the battery from the remote for one day. See if it stays off. If it does replace the remote
Posted on Aug 31, 2010
SOURCE: I have two (2) 16 in Stand Fans (AECS16W) Both
Hello Pjhenger,
Please call the Wind Chaser assistance number 800.
If you are directed to send in your product, send it postage prepaid to:
WindChaser Products, Inc
4130 Del Rey Avenue
Marina Del Rey, CA 90292
Attn: Customer Service
Please make sure you include your name, address and phone number.
You can also call toll free phone number is 1-800-405-2943. You will be directed to a Customer Service Rep. Monday thru Friday, 8:30 am - 4:30 pm PST.
Posted on Jul 04, 2011
BROKEN BLADE OF TABLE FAN
obtain new blade and replace same.
https://yourhome.honeywell.com/home/.../ContactUs.aspx
Jan 11, 2014 | Honeywell HT-800 Table Fan
Purchased a new stand fan but after few days started giving trouble by not running after stop. Few days used to open the covers fix up the blades and then restart. now it is not running at all. what to do?
The motor has gone bad... the best thing to do is to take it back and get another one... often if a motor is bad it will fail very quickly like that...
Heatman101
Aug 28, 2010 | Honeywell HFS641P Stand (Pedestal) Fan
How to open fan to clean blades honeywell model
first remove the two screws on the back top of fan... then remove little cover on third screw which is located on the bottom of the outer casing.. i used a fork to poke the hole for leverage then pull it out... take out the three screws on the bottom (that hold the stand part of the fan).. now you can start removing the casing.. start to pull apart.. carefully... once you have opened one part you can use a flathead or a butter knife to pry open where there are clips on the sides.. the final clip is under the handle poke that one and your fan should be opened....
Apr 15, 2010 | Honeywell Dryers
Fan stopped working
Hi and welcome to FixYa,
Offhand, moving the fan from one room to another should not cause it to cease operating. A couple of ideas you may want to consider/try:
  • with the multimeter set to X1, check the resistance of the 2 prongs of the AC plug;
  • selecting each of the speed other than OFF should show a reading;
  • if there is a reading on any speed selection and yet the fan will not turn, with the fan unplug, turn the blades manually. it should rotate freely/easily. If not, then possible dirt accumulation on the bearings or a stuck up;
  • if there is a reading, the blades turn easily and selecting any speed, the motor only hums but not turn, then the start up capacitor is faulty;
  • if no reading at all, then the unit has to be opened up to expose the rear of the switch and the wirings inside;
  • check for the continuity of the AC cord from the plug to where it enters the body of the fan;
  • if everything checks out, then suspect the motor. To check motor, there would normally be 6 wires from the coils; 2 for the starter capacitor, 1 for the common and three for the different speeds. Check their continuity.
Good luck and thank you for using FixYa.
Feb 14, 2009 | Honeywell HS-300 16'' Stand (Pedestal) Fan
Cleaning a 14F0 Honeywell Fan
thank you for using fixya. The blade cage has locks and screws that you can remove from the back. once the cage has been removed, you can remove the blade attached to the motor using a vacuum cleaner or you can remove the blades by undoing the screw on the center detaching it from the motor.
Jan 04, 2009 | Honeywell HV-180 Floor / Box Fan
Honeywell HS-300 16'' Stand (Pedestal) Fan Logo
37 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
