When I press PROG on my Toshiba M-672 VCR it goes directly to the menu screen showing PROGRAM, SET UP and PRESET, but all in Spanish. I want to change the language to English, but when I follow the Intital Setting directions in the manual, it does not go to the Language screen first as indicated, it goes to the one I described above. How do I correct this?
  • Televison & ... Master
  • 5,444 Answers
Try looking in the manual for setting the 'factory default'. And as long as it wasn't made for the Spanish market it should return to normal. It will of course have to be all set up how you like it again though!
Posted on Jun 04, 2010
How get menu to show language option
Press the vcr button then press menu,press the play or stop button to select vcr set up,then press the fast forward button.Press play or stop button to select language,then press the fast forward button.Press the play or stop button to select English or Spanish.Then press the status exit button.Hope this helps.
Oct 11, 2014 | Philips VR620CAT VCR
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
press
to select:
1~31= one time, or
DAILY= MON~ FRI, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
press
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
press
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Or
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
How do I set the clock on a fisher fvh-7600 vcr I do not have a owners manual
Also having no manual for a Fisher FVH-7600, I eventually guessed how to set the clock after finding a remote control (Fisher RVR-7600) that works with it.
With the TV and VCR connected and powered on, the TV set to channel 3, and the remote's FUNCTION switch and VCR/TV button both set to VCR, I see a blank blue TV screen.
Then I press the PROG. button on the remote, and a menu with instructions appears on the TV screen. CLOCK SETTING is item 1 on that menu.
Sep 23, 2014 | Televison & Video
My answering machine is in spanish and I can't figure out how to change it to english, can you help me?
Press the flash/prog button until 1ENG 2FRA 3ESP shows on the display.
Use the CallerID/Vol (+ or -) button or the handset number pad to select 1 (English) 2 (French) 3 (Spanish)
Press the flash/prog button to confirm and to advance to the next menu item.
I hope this helps. Have a great day.
Jul 08, 2011 | GE 25861GE3 Twin Cordless Phone
How to change spanish to english when phone fell from bed it now is in spanish
1. Press the flash/prog button until 1ENG 2FRA 3ESP shows in the display.
2. Use the Caller ID/vol ( + or - ) button or the handset number pad to select 1 (English), 2 (French), or 3 (Spanish). The default setting is 1ENG.
3. Press the flash/prog button to confirm and to advance to the next menu feature.
You can download the manual at
http://www.home-electronics.net/USER-GUIDES/25861_CAN_EN_CL_IB.pdf
Jun 21, 2011 | GE 25861GE3 Phone
Having Difficulty programing Woods Brand electrical timer !
How to program Woods 59377
Timer has rechargeable battery.
Plug timer into wall to charge battery to see LCD display.
Download Woods manuals
59377 manual
Up to 8 ON/OFF programs per day >> program 1 program 2 ... program 8
Choice of individual days, or blocks of days
Image shows buttons:
Set time of day:
Hold down CLOCK until settings are made
Use DAY button to choose MO - TU etc
HOUR button to set current hour
MIN button to set current minute
Release Clock button and time is set
Program preview
> First I suggest you write out your schedule to avoid conflicts in programming
Manual says:
>For each ON time, you set DAY HOUR and MIN
>For each OFF time, you set DAY HOUR MIN
>Manual shows blocks of days to choose from > for example TH FR SA is one choice; MO WE FR is another choice ,,, 9 possible blocks of days to choose from
Looking at display is critical for programming timer
Look for the number 1 or 2 or 3 etc located on left of display > each program has a number
Look for the word ON that indicates you are setting ON time for program 1 or program 2
Look for word OFF that indicates you are setting OFF time for program 1 or program 2
Program timer
Press PROG once and look at screen ... you will see '1' and 'ON' in tiny letters
Do not hold down PROG button
Press DAY to choose block of day for program 1
Press HOUR to choose ON hour for program 1
Press MIN to choose ON minute for program 1
Press PROG button once to finalize ON time for program 1
Before pressing any more buttons, look at the screen >>> screen shows '1' and 'OFF' in tiny letters
So you are ready to set OFF times for program 1
Press DAY >>look at your written schedule to make sure the correct block of days is chosen >> if you chose ON for TH FRI SAT, do you want OFF on same block of days?
Press Hour
Press MIN
Press PROG to confirm OFF time
Before pressing any button, look at screen and '2' and 'ON' show on screen
Press PROG to advance to program 3 through program 8
Press ON/Off button to exit programming
Other features
Daylight savings time: Press HOUR & MIN simultaneously and clock springs forward 1 hour ... press again and clock falls back 1 hour
Look for S in display to see if timer set for S summertime
Press reset to clear all programming
Oct 07, 2010 | Woods Industries 59377 Indoor Digital...
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Setting the clock/time
There should be a menu button on the remote which will get you into the various advanced programming functions. Many/most of the late VCRs cannot be programmed, time set with the buttons on the VCR itself.
Mar 12, 2008 | Televison & Video
Program button goes to fuzz channel, no regular channels show up
Yup, I went through a lot of grief one time only to discover the old 3/4 channel switch!
Dec 24, 2007 | Toshiba W522 VHS VCR
Turning on VCR for 2nd time recording
Have you fixed your problem?
If not, just try pressing the dvd/vcr button, so the vcr becomes the primary device. Now you can press setup and go back into the vcr menu.
Nov 11, 2007 | Toshiba SD-V394 DVD Player/VCR
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
