Question about John Deere Kawasaki Kubota Lawn Starter 190531 ()
Any tricks to removing the starter on a L1801 Kubota
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
Just one tip: Disconnect the battery first. The starter is connected by a heavy gauge wire to the battery positive terminal, with no fuses. Accidentally shorting that line to ground could cause a battery explosion (I knew someone blinded for life by just such an accident). Safest method: disconnect the negative (grounded) battery terminal first. While that should be enough, I also take the positive connection off next, and clean and grease both battery terminals while I'm at it. With that done, the starter is easy to access with the loader and motor cover off. Take off the nut holding the heavy red wire (under the rubber boot) and remove the plastic connector (sometimes there's a locking tab you have to press in). Unbolt the starter and replace it. Put some dielectric grease (vaseline works too) on the connections before putting them back on. Reconnect battery -- positive terminal first, negative last, and off you go. Please rate if you found this helpful, thanks!
Posted on Jun 02, 2010
Testimonial: "Very helpful"
Installing starter solenoid for kubota b7200 tractor
What is the question? These are DENSO Starters. very easy to work on. Take off 4 small screws and Plunger and Contacts are very accessible.
Sep 01, 2017 | Kubota Garden
Starter problems with Kubota l3010 tractor
Could be the solenoid need more information does it click make any noise .Year make an model
Jul 20, 2016 | Kubota Garden
Need wiring diagram for Kubota t1770
check grounds first & then have starter & battery tested
Oct 27, 2014 | Cars & Trucks
Find the relay on a kubota
jump starter with battery if starts look for bad ignition switch or battery dosnt have enough amps or bad contact in silinoid you have to buy one to find out
Sep 12, 2014 | Kubota Garden
Why my kubota L 3240 will not start
Sounds like the starter coil is grounded or the starter is bad. Have it checked. It is usually free if you remove starter and take it to Kubota Dealer.
Jul 31, 2014 | Kubota Garden
Kubota 9540 starter diagram
check battery check to make syre you are getting power to small starter wire when key is turned
Oct 18, 2012 | Cars & Trucks
I have a kubota bx25 that won't start. it has power to the starter on battery side
you need to have power to the small wire on the starter for it to crank over
Sep 03, 2012 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
John Deere Kawasaki Kubota  Lawn Starter 190531 () Logo
154 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
