Question about Memorex MVD2040 DVD Player
Disc door will not open
Disc door seems jammed--will not open when it says "open" in the lighted read-out
  • 484 Answers
the reason the disc door would not come out is because there is a problem withe the mechanism that opens the door.
to fix this,
1. you unscrew the dvd player,
2. take off the cover,
3. plug the dvd and press open to see if the door would open, then you will see where it is getting stuck,
4. replace the mechanism that is controlling the disc door, and press open to see if the door will open.
5. once it is able to open up, you can screw back the cover.
Posted on Jun 02, 2010
Panasonic dvd video camcorder VDR-M55PP
system malfunction, put a soft reset on the camcorder.
Feb 24, 2008 | Panasonic NV-DS65 Mini DV Digital...
Dvd door won't open
Someone is going to have to open the unit to see what is happening--either a disc is jammed inside or a mechanism problem.
Sometimes with unit apart you may be able to gently probe and free the jammed area--possible also something that does not belong there got inside--look closely.
Jun 16, 2012 | Daewoo DV6T-81N DVD Player / VCR Combo
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
The magnetic weight thats mounted on top of the dvd drive on the inside has came loose and jamming the door. Also it wont read the discs if this happens. I repair drive issues in PS3 and 360's with 99% success
Jan 22, 2010 | Microsoft Xbox 360 Console
CD changer won't open
There may be a jammed disc in the mechanism - if there is no manual release near the door (there isn't usually on these systems), you may have to open the case and look to make sure there's not a disc jammed somewhere in there.
Mar 13, 2009 | JVC UX-S57 CD Shelf System
Can't get the disc out...
is the light flashing on the drive ? .... be that as it may you will note a small hole on the face of it.... put a small round object in there and push... that should open the door.
Mar 08, 2009 | LG GCE 8523BB (GCE-8523BB-10PK) CD-RW...
How do you manually get the disc to eject? the
There is a small hole just below the disc door. Straighten a paper clip or some like object and push it into that hole. It should release the tray. The clip will go in an inch or so before it contacts the door release. This given that it is not jammed by an improperly inseted disc or something. In that case you will need to pull the drive out and take the top off. Good luck
Feb 18, 2009 | Toshiba Televison & Video
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
CD tray won't open it tries but stays shut
Read. The. Fine. Manufacturer's. Manuals.
A disc is probably up on an edge and jamming it. Use a pin in the emergency release and another at the top of the door to scoot the disc down into the tray.
Nov 22, 2008 | Computers & Internet
Memorex MVD2040 DVD Player Logo
1,188 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
