Question about Craftsman 10" Table Saw
My saw will start. It has always run quite well,
My saw will start. It has always run quite well, but yesterday it would not start. could it the reset or on/off switches are bad?
  • 59 Answers
If it hums but doesn't turn it is almost certainly the starter capacitor which is fairly easy and cheap to replace . Usually a metal or plastic cylindrical object attached to the motor or sometimes inside the switch housing. Buy a replacement from Electronics store or from the makers of the machine.
If it does not hum and you have checked fuses then the switch is probably the trouble and switcheds dont like dusty environments at the best of times.
Posted on Jun 03, 2010
Why wont it run?It ran yesterday for a minute until i turned it off.I unhooked neg.battery cable now it wants to start but just tries and pops and backfires thru intake!!!WHY?
Want to help you but can you provide some imfo like year model etc of your car .all cars runs if you have both gas and spark
Feb 15, 2016 | 1997 GMC Suburban
Stops running when plunged into floor
Always start with a fresh plug. Try to get non-ethanol gas. Check to see if the little weight and filter are still on the little hose in the gas tank.
Nov 26, 2013 | Husqvarna K970 Ring Saw
445 HUSQVANA SAW QUITS
Sounds like fuel starvation, always start with simple things first, replace the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of leaking.
Jan 18, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
1992 lumina will not always start after running. has quit at hwy speed and then not restarted until the next day. new filter does not solve problem. drove 30 miles yesterday fine, and 10 minutes later...
Sounds like a fuel pump problem or the cam or crank sensor are starting to go hope this helps ya out or gets ya started on the right path good luck
Jul 21, 2011 | 1992 Chevrolet Lumina
Mcculloch 3516 chain saw, does not always start.
It must have spark, fuel and compression to run. Your task is to figure out which is missing.
Sometimes electrical components quit operating once beyond a certain temperature. Does it always start cold and become tempermental when warm?
IMO most hard start problems on a chainsaw with a good fuel delivery system are flooded.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
The 3516 is a MTD McCulloch (Chinese). These saws are in a class by themselves. Good Luck
Lou
Nov 15, 2009 | McCulloch Garden
Homelite xl chainsaw revved up & quit and won't start now
I suspect you have a fuel delivery problem or a dirty carburetor. As a chain saw runs out of fuel they often revv slightly (running lean). HTH
Lou
Oct 06, 2009 | Garden
Engine starts and runs a few seconds and quits
It sounds like your carburetor needs cleaned. If you started it for the first time without emptying the old gas, you may have had dirt particle's that had settled at the bottom of the tank. This would explain why it had ran the day before. If you need further assistance on how to clean the carb., just let me know.
Jim
May 24, 2009 | Remington Electric Chain Saw
4 y/o oulan chain saw hard to start and quit running, no spark.
TRY RUNNING AT HALF OR FULL WHEN IT DOES POSSLBY BAD GAS/MIX IF YOU CHANGED THAT ALREADY CARB PROBALY NEED TO BE CLEAN
May 02, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Craftsman 10" Table Saw Logo
242 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
