Question about HP Officejet 6310 All-In-One InkJet Printer
Will not print defults to fax even though default is set for printer
    Scholar:
  • 53 Answers
Delete both the icons(Fax and Printer icon) and also, if there is any copy if installed.
Insert the Printer driver CD or Run the setup file.
Select Add a Device from the Options that come on the welcome screen.
Select it, follow the onscreen options to complete the installation.
Once it is complete, restart the printer. And then try to print. If the issue still persists, restart the computer and then try to print.
Posted on Jun 02, 2010
Force Canon iR2270 to always pull from a specific drawer.
There are no need to crazy brother, Print document from any tray is does not control by the window driver in default mode, u have to select the tray from machine in which u want that printout are coming by default,,............
First Of all Pull out ur tray from which u want to print outs are comming by defult, than there is a small gear under circle where u set the page size, in the corner of the tay, u have to turn in toward the ltr mode, after that machine automatically pick up the page from this tray by defult
Dec 14, 2012 | Canon ImageRunner 2270 | IR2270 |
How to set defult?
If you are using Window XP, 7 then goto Control panel->Printer and Faxes->your printer installed over there usually marked with a small tick on icon->right click on it ->if displays set as default printer the click on it else go to printing preferences and on the last tab there is option to make it a default printer
Nov 30, 2011 | Epson Passbook PLQ-20 Matrix Printer
Connecting a laptop to the printer
install the printer dirver (cd driver) on your note book
set it as defult printer in (start menu >printer and faxes > right clik on printer> choose set defult)
Nov 10, 2011 | HP DeskJet 5150 InkJet Printer
Sx515w Epson- Sounds silly but how do you print out pictures from your computer in black and white? i have tried everything and it doesnt work it still comes out in colour even though its my daughters...
It will be your printer settings, although different, yours should be similar:-
Start - Printers and faxes - RMB default printer and select properties - Advanced - Defaults - Main - Check the Grey Scale box.
You may want to upgrade the print quality aswell if printing a photo.
Apr 29, 2010 | Epson Office Equipment & Supplies
HP Photosmart C7180 won't print!! I had an IT person come to my home earlier today, and it was printing when she left. Not 20 minutes after she left, it wouldn't print for me!!! This is the second time...
It would seem that your default 'printer' is set to fax and not print.
When you select print from the file menu it probably says something like HP Photosmart C7180 Fax in the printer option. If it does, go into the printer section from the control panel and make the C7180 (without the fax reference) the default (right click>set as default)
Oct 15, 2009 | HP Photosmart C7180 All-In-One InkJet...
Printer always says its offline even though its on and connected
If you are Windows XP Operating System, perform the steps below:
1. Click Start --> Printers and Fax.
2. Right click the printer icon and check the following:
a. Check whether the All-in-One is set as default printer.
b. Ensure that the there is a check mark on the "Use printer online". If you have the Use printer offline, make it online by selecting the option.
c. Ensure that there is no check mark on the Pause printing.
Check for the default printer and USe printer Online in the printers and faxes folder.
Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
Sep 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Printer prints double sided only even though set for single
This is cause duplex printing option is enabled in the driver. If you have win XP, go to control panel and then printers & faxes.
Right click on your LJ P2015 printer driver and click on properties.
Click on the tab 'Advanced' and then click Printing Defaults.
Remove the check mark for 'Print on both sides' under the 'Finishing' tab.
Click Ok and Ok again.
Nov 21, 2008 | HP LaserJet P2015dn Printer
Won't print to right tray
I had this problem and solved it like this:
  1. Right click on printer driver in printers and faxes.
  2. Select printing preferences
  3. Choose paper quality tab
  4. Set paper size (A4 in my case)
  5. Set paper source to printer-auto-select. This is different from the default "Automatically select"
As long as tray 1 is empty, tray 2 should now kick in. Setting the paper source as tray 2 didn't work at all.
You seem to have to set this on each client computer though - even if you are sharing the printer over a network (4200n).
Sep 23, 2008 | HP LaserJet 4200 Printer
Does not print
check your printer configuration and default setting choose the name of your default printer.
Sep 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
