Question about Canon EOS Digital Rebel XTI Digital Camera
No power Canon XTi was working properly this morning. This afternoon there is zero power or it will not switch on. Took camera to one camera shop their answer was take it to the battery place and have it tested. We knew the batteries were properly charged and in working order but took them anyway. There are two different batteries and both tested full and in proper working order. Any suggestions? We have taken the battery out and let it sit.
  • tptmk Jun 03, 2010
    had not taken the card out of the slot in between working and not working. Also visibly there are none out of place. Is there an internal fuse/reset type device within the camera?
  • 94 Answers
Camera is dead i think it p fuse gone from md board.
or camera is making battery drain everytime whe you insert battery.
There could be main pcb or md baord or battery box unit.
take it to canon repaire centre and tell them to give you estimate
Posted on Aug 10, 2010
My Canon xti stopped working at my son's graduation. I had a full battery and took a few photos.....then turned it off.....and when I turned it back on again, it was completely dead. Tried several...
Hiyou might have a problem of either main pcb or power control pcd (dc/dc convertor). it is common but it cost. It cause usually come from loosen screw going around inside and short. If it is lucky, then your unit would just a fuse brown. If not, it has to change main pcb and all of computer adjustment is involved. Your local repair shop would charge you around $65 to 235.
Jun 04, 2011 | Canon EOS 400D / Rebel XTi Digital Camera...
My Camera turns on But will not take a picture, I push the button to take a picture and it doesnt do anything! I took the batteries out, charged batteries, took out the lens, took out the card, and put...
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 06, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon xTi won't power up
I think the problem is that these cameras are very sensitive to the battery being taken in and out - if you leave the camera swtiched on, and remove and re-insert the battery, it can cause a very small fuse in the camera to blow. Always ensure the camera is switched to "off" before doing anything with a battery...
You can fix it yourself if you are happy disassembling a very delicate piece of hardware!
Feb 05, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
I have a Canon EOS400D. Every time I try to take a flash photo there is a repeated clicking sound with error message 5 saying, "the built-in flash's auto pop-up was obstructed" yet I don't see anything...
The flash up switch is not working properly. It probably just needs to be disassembled and cleaned. About a $125 repair at most shops.
Hope this helps.
Wes Kauffman
Jan 05, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Switch from film to digital cameras.
I also own a Vivitar 285 that i used with my Canon F1 manual 35mm camera. Most older cameras before the advent of digital, had a hot shoe on top of the camera, or like in my case, the hot shoe went over the rewind knob. I also had to plug in a power cord from the 285 flash foot and the cameras PC connection in order for the flash to work on some other cameras. The Canon Rebel XTi has a TTL (through the lens) hot shoe usable with Canon's own EX flash units. You can buy a "hot shoe to PC connector" if the TTL camera hot shoe doesn't work, but be extremely careful, the only problem that exists with the older manual flash units was the trigger voltage is as high as 200+volts which would fry digital camera hot shoes. I tried my unit with a Wein flash trigger device on the PC cord of the flash and my Canon D60 with it's own flash. All shots were overexposed and washed out highlights.  Here's a copy of the hot-shoe review:h The EOS 400D's hot-shoe can be used with Canon and third party flashes (although sync only on most third party units). The hot-shoe is E-TTL II compatible. Compatible flashes include Speedlite 220EX, 380EX, 420EX, 430EX, 550EX, 580EX, Macro-Ring Lite, MR-14EX, Macro Twin Lite MT-24EX and Speedlite Transmitter ST-E2.  The Canon Rebel XTi doesn't have a PC socket to plug in a manual flash trigger cord which common sense tells me there is no provision to step up the voltage to trigger manual flashes - so my answer is this combination is not a good idea on a Canon Rebel XTi. Hope this helps.
Dec 12, 2008 | Vivitar 283 Flash
CANON REBELXTI
If it is still in warranty, it is better to send it for repair with canon or with the extended warranty company.
If it's not in warranty, then you have to send it for diagnostics and repair.
The reason for such failure may be:
1. Defective DC/DC power board;
2. Defective main board
Diagnosctis and repair of this problem requires a repairman with skills and tools to do it properly.
Depending of what is broken and to whom you send your camera for repair, the repair cost may be in in the range of $100.00 - $200.00.
Best regards,
Oct 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D
The camera is working again. I took out the battery, with the the on/off switch, off. I then swtiched the On/Off switch On. I then put the battery in ,and the camera turned on.It then gave me an ERROR 99. I then switch it off and on again, and it is still working.
Apr 28, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
No power
This definitely looks like an issue with the Camera. I suggest contacting the Camera Tech Support immediately and request them to send the Camera to the service center. There are more Canon Rebel XTi owners, including me have experienced no-power issues albeit not exactly similar. More discussed here: http://www.fixya.com/support/t270989-xti_wont_power_up
I also do not think that any user action can fix this issue. Just call the tech support, and they may say that they never heard of this issue, please point them to this thread. Good luck.
Feb 21, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
CF Error
I had the same symptoms. I took it to an authorized Canon repair shop. For $150, they resoldered connections on my 'power supply board'.  No idea why the solder gave out. It's working great now.
Jul 09, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Canon EOS Digital Rebel XTI Digital Camera Logo
236 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
