Question about HP Photosmart 4180 All-in-One Printer
I cannot get my printer to scan and my pc isn't
I cannot get my printer to scan and the ho software isnt recognizing it being connected to my pc. I can print but I cannot scan or use any other function. I have a HP deskjet 4180. Thanks
    Scholar:
  • 53 Answers
Follow the steps given on the document. Click on the link to open the Web Document.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01290511&cc=us&lc=en&dlc=en&product=3177566
Posted on Jun 02, 2010
How do I get the scanner to work on my computer
your printer probably has a software to install.
this software has the mode to scanner and to scan. the pc has a printer connection right? and.... how to scan should be on the software for the printer. it recognizes the printer and it's looking for a scanner, this is why is telling you scanner connection under the scanner connections but if the use is with the printer as a scanner, it must've a software. maybe the printer a scanner button so the pc recognizes it as scanner.
Jan 22, 2015 | Office Equipment & Supplies
I cant get my 4650 to scan it keeps saying downloading application list but it never does anything
If you are scanning documents to edit or save as PDF file, you will need to install the OCR scan software on your computer. The Lexmark OCR scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center to request for one.
If scanning from your printer to your computer was working previously, then it could be just a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected) > reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to scan again once the computer fully recognizes the USB connection (if USB connected). If printer is connected wireless, wait until the WiFi light on the printer turns on solid green before trying to scan a document.
Dec 28, 2011 | Lexmark X4650 InkJet Printer
My printer want scan to pc
printer wont scan to pc - Lexmark X5650 ALL-IN-ONE PRINTER
Dec 05, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
Why won't my printer scan a document to my laptop?
Make sure the Lexmark OCR scan software is installed on your laptop. The software is available only on the installation disc that came with your printer. If you still haven't installed the software on your computer and you don't have the installation disc, please contact Lexmark Technical Support Center to request for one.
If you were able to scan documents before using your Lexmark printer, it could be just a slight communication issue. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
Dec 01, 2011 | Lexmark X5650 All-in-One InkJet Printer
Why isn't it scanning a document to my laptop
Do i need software like ocr so that the lexmark x6650 scanner can work
If you are scanning documents for editing or saving them as PDF, you will need to install the OCR scan software. The Lexmark OCR scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center to request for one.
If your scanner was working before, it could be just a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to scan a document again to verify that the problem is fixed.
Nov 02, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
I cannot use the scan function on my X5470--specifically, to scan documents into PDF format. "Cannot retrieve Application List" is the messge shown. How do I repair this function?
Make sure the Lexmark OCR scan software is installed on your computer. The software allows you to scan your documents to PDF file. The software is only available on the installation disc that came with your Lexmark printer. If you don't have the disc, please contact Lexmark Technical Support Center for assistance.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 15, 2011 | Lexmark X5470 All-In-One InkJet Printer
I can't get my scanner to work it says try starting scan from put
First you have to load the scanner (twain driver). Then load the scanning software. Then plug the printer/scanner into the usb port on the pc. The pc should then recognize the scanner. You might have to turn your pc off then on again to recognize the scanner. Then try to open the scanning software on your pc and put the document on the scanning glass and press the aquire/scan button on the software. Hopefully, that should work.
Sep 14, 2009 | HP PSC 2410 All-In-One InkJet Printer
HP Photosmart 4180 All-in-One Printer Logo
129 people viewed this question
Seeker5211
Seeker5211
