Question about Bosch Classixx WFL 2066 Front Load Washer
My washing machine is making an awful noise when its changing direction on the drum motion and changing programme. its sounds very much like some sort of ball baring has come loose. - what doi I do please ?
    Sergeant:
  • 228 Answers
Put the machine onto drain position if it still makes the noise it is something stuck in the pump check and clear filter if makes noise only when drum turning then is highley suspect bearings have failed.
Posted on Jun 06, 2010
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
Nov 12, 2013 | LG Washing Machines
Indesit W123 drum not moving. Will turn freely and quietly both directions if spun by hand. Sounds like going through cycle and dial turns as is going through programme. Made a whirring noise when ini
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 20, 2013 | Indesit Door Handle Kit for W123, W133,...
Rinse Light flashes on Miele W829 novotronic
Remove all the load and try to move the drum manually clockwise and anti clockwise. If you notice any friction check the motor separately and the agitator assembly separately.
It could be due to alignment shift causing a wobbly motion or a failure of the bearings.
Check these links:
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlForreplacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html.
Jul 29, 2012 | Whirlpool Washing Machines
My 2005 Whirlpool Gold Ultimate Care II washer makes a thump/click sound during the wash/rinse cycles. It also sounds like it is slipping gears or there is something caught that is catching every so often....
Jun 29, 2011 | Washing Machines
I have a Hotpoint Aquarius WF541 that has started making ean extremely loud noise when on spin. The machine remains still, but sounds like a jet engine. The drum makes an awful noise when I turn it...
maybe it the pulley tensioner came lose.....open up the back of the machine and check if the belt is tight...if not get the spanner out retention the pulley arm and retighten.
Jul 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
My washer makes loud noise during the spin cycle. I think the drum is off center. How do i fix it?
try moving the cloths around to even the load out my washer does this alot.
Nov 25, 2009 | Washing Machines
Have a hotpoint ultima . very noisy
I'd check very carefully to see whether the washer is level. You can get a level pretty inexpensively at a hardware store if you don't have one or can't find one to borrow. A fraction of an inch can make a big difference.
If that seems OK, if it is a top-loading machine, use an appropriate size level to see if the drum is level within the washer when it is sitting still. Also, on top loaders, you can usually push the drum manually about half an inch or so in any direction. When you do this does it feel as if it is binding in a particular direction? If so, maybe you can take it apart enough to figure out why.
Sep 19, 2009 | Washing Machines
Fast spin vibration
Is the bearing for the inner drum loose or the drum turning with a wobble (empty)? If that checks ok, then possibly one or more of the outer drum dampers is broken, worn out, or out-of-place. Shake the inner drum in various directions--there should be damped motion in any direction.
Aug 08, 2009 | Washing Machines
Bosch Classixx WFL 2066 Front Load Washer Logo
402 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
