Question about Behringer POWERED MIXER, 20 CH, 400 WTS AMPLIFIER => Model PMX5000 Car Audio Amplifier
My powered mixer Behringer is buzzing
My Behringer powered mixer has a 24-bit multi effects processor.
When I chose certain effects, it starts to buzz.For example : when I choose Room or Ambience effects it starts to buzz. When I choose Delay & Chorus effects it doesn't buzz.
Which can be the problem ?
Regards,
Ersin
  • Jeremy Plummer
    Jeremy Plummer Jun 05, 2014
    I have the same issue with my Xenyx 2442USB. The buzz is specific to using those particular FX, and buzzes in sync with the 'tap' pace. I would LOVE to know if anyone understand what the problem is. Other than that, I LOVE this board.
  • Behringer Master
  • 5,603 Answers
Make sure the buzz doesn't happen because of feedback of speakers into mics. When feedback is processed it often goes to a buzz instead of the usual howl.
Also check that you are running adequate inout into the effect since a very low inout will incur digitizing noise and loss of signal=to-noise ratio.
Posted on Jun 04, 2010
Starts playing fine. After an hour, why does sound give way to a loud buzzing?
If it goes back to normal after you shut it off and letting it sit for a bit, it's related to heat buildup. If that's the case, it's either a component failing or a cold solder joint that opens when a part expads/contracts from itr's contact point. Either way, you needto take it to the repair shop.
Jul 27, 2015 | Behringer DJx700 5-Channel Pro DJ Mixer...
How do i set up my behringer xenyx 1622fx multi-fx
First read the instructions they contain some amazing information. I can not help you because I have no idea of what you want to know.
Jun 02, 2014 | Behringer Xenyx 1622fx Mixer Multi-fx...
How do i set up my behringer 1622fx 24-bit
First read the instructions they contain some amazing information. The setup is a subjective function and dependent on what equipment you are connecting to it.
Behringuer pmp 5000 turns off
Can you elaborate a bit more about what you mean by "turning off?" What are you doing up until that point? Does it do it at certain times, etc.?
Apr 12, 2014 | Behringer DJx700 5-Channel Pro DJ Mixer...
Ic burned
which ic burnt? if in the output (amplifier) stage it is probably a transistor (or pair) that went out. you will also need to replace the biasing resistor and diode. if in the input/preamp stage any general purpose 8 pin op-amp will work. Be careful when soldering this unit, it has a multi level circuit board. If this unit is out of warranty (over 2 years old) It will probably be more economical to purchase another unit imo. good luck.
Mar 22, 2014 | Behringer Pmp6000 Powered Mixer 1600w 1600...
Behringer ub802 mixer is buzzing even when no input when i hook my head phones into the headphone jack and main output jack
If it buzzes when you have no inputs AND no output leads connected, there is a problem with the power supply... HOWEVER if you have used UNBALANCED output cables instead of the REQUIRED TRS BALANCED output cables, it is possible the noise is being driven backwards and that is what you are hearing. Note that at full gains, there often is a tiny bit of noise, usually hiss. Also make sure the supply is powered from the SAME receptacle as the equipment this drives such as an amp or powered speakers.
Jul 18, 2011 | Behringer Eurorack Ub802 - Ultra Low-Noise...
When i have my FX on and sending to main they make a horrible clicking (shorting out) sound. if I push the main mix button it shuts off the effects and the noise goes away...bad side...then I have no...
Check the 5 volts to the FX unit, If the voltage is low, the FX processor will keep reseting generating clicks, In a different product, the 5 volt filter cap was degraded and voltage dipped down to 4.5 volts causing resets.
May 31, 2011 | Behringer EURORACK UB2442FX PRO Mixer
My effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Oct 19, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Car Audio & Video Logo
439 people viewed this question
Top Behringer Car Audio & Video Experts
xxxxxx xxx
Are you a Behringer Car Audio and Video Expert? Answer questions, earn points and help others
