Question about Refrigerators
Side by side refer.Cold air only in the bottom half of the fridge and freezer,nothing in the top half.Removed panel on back wall of freezer plastic fan is working.
  • hughes_bobby Jun 02, 2010
    side by side fridge.only have cold air middle down in both the freezer and fridge.warm middle up
    Whirlpool side by side,only cold middle down in both freezer and fridge. Does this sound like defrost timer.
    President:
  • 949 Answers
When you pulled the panel off and looked at the fan in the freezer was the coil below that frozen up solid with frost?
Posted on Jun 03, 2010
  • hughes_bobby Jun 04, 2010
    It was not frozen.
  • Philip Jun 04, 2010
    Thank you for the information. If it was not frozen up then it would not be a defrost timer problem. Since you are getting only partial cooling in the bottom of both and the fan is running we only have a couple of things that could be causing this.
    The first thing we could have is a short cycling issue with the compressor. Check the coils below the refrigerator and the fan in back. What we are looking for is how hot they are and if the fan is running below to keep them cool. If they are very hot then that may be the problem, clean them good and make sure the cooling fan is running in the back bottom of the unit.
    If these coils are warm and not hot or room temperature we have a problem with the sealed system most likely. This would typically be a refrigerant (freon) leak, or a weak compressor, either of which would need a professional to make repairs.
    Let me know if you have questions.
  • Refrigerators Master
  • 3,083 Answers
I found the same problem you're having in a blog on a website, and their problem was a burned out defrost control board. It's probably an inherent weakness with this model, since it's happening to more people than just yourself. The blog talks about using a surge protector, etc., however, having been in the electrical field for all my life, I would say the fault is probably with a slightly under-rated control board. Check the board for any burned parts, wiring, etc. Chances are that it's the culprit.
Here's the blog:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/91403-frigidaire-side-side-not-cooling-freezing-top-half-only.html
Here is a blog where the tech explains that the board can be cleaned off and restored. The explanation is near the bottom of the blog, but the scenario fits the problem you're having.
http://appliancejunk.com/forums/index.php?action=printpage;topic=5178.0
The defrost control board is going to be the problem, but maybe it just needs a good cleaning, which can restore it. Good luck, and hope this helps.
Posted on Jun 02, 2010
  • 1 more comment
    Mine is a Whirlpool not Fridgadaire
    Does the refer brand have anything to do with your answer?
    Are you still there?
    Top Expert:
  • 80,607 Answers
They most common cause of this is that the Defrost timer is defective, the timer on most models is located in the front under the plastic grille at bottom of fridge, below is a typical timer location diagram.
  • 12 more comments
    I see no defrost timerin bottom front of fridge,maybe somewhere else.
    I also noticed some mold on the freezer side of the unit mostly middle up.
  • yadayada
    yadayada Jun 02, 2010
    As i said it is a "Typical" spot, go to this web site www.repairclinic.com put in your make and model number and look up the defrost timer, there will be a diagram
    Would the defrost timer effect the ice maker
  • yadayada
    no thte ice maker is another very expensive problem, does it provide cold water.
    only at the dispensor in the door
    Thats right
  • yadayada
    best thing to do is replace the ice maker as a unit assembly
    Ok but the ice maker dosen't have anything to do with my original problem,right.
  • yadayada
    the ice maker is a whole separate issue as i already stated. based on my experience i wouldn't waste the $200-$300 to fix it.
  • yadayada
    may i ask what answer are u looking fior here?
    I want cold air throughout my fridge.The ice maker isn't important.
  • yadayada
    yadayada Jun 04, 2010
    You asked for expert help I gave you the most common part that causes your symptoms, the defrost timer, if u want to use this appliance anytime soon suggest you try that. Thanks
What causes the coils behind the panel in the freezer to freeze up and stop the freezer fan? top half of freezer defrosts, lower half stays cold.Fridge is side by side and freezer fan keeps turning of
When the evaporator fan motor stops running the top half of the back wall of the freezer will frost over and the the only reason the lower portion stays cool is because cold air falls. More than likely you have a a dc motor fan and its bad, but be wary with ge, the main control board could also go bad causing the fan not to run.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Sep 05, 2012 | GE Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
I have a Jenn-Aire side-by-side refrigerator Model #JCB2280HES, Serial #10024253EP. The warranty expired in February 2010. The food in the bottom half of both the freezer and refrigerator is frozen and...
Hi!!
Check to see if the evaporator fan behind the freezer wall (remove wall) is running. If it isnt the air will not flow properly in the unit. Replace the fan motor and it will fix it.
Good Luck!!
Jul 29, 2010 | Jenn-Air JCB2280HES Side by Side...
Bottom half of fridge and freezer are cold top half warm?
This sounds like an air flow issue, If your freezer fan is running still you may have a defrost problem starting in the freezer cooling coils. This will cause the cold from the freezer to back flow into the bottom of the fridge and only the lower half of the freezer to keep very cold.
Most likely culprit for defrost issues would be the terminating thermostat (inside freezer behind back wall and clips to top of coils).
Good luck and let me know if you need more help!
Jun 14, 2010 | Amana 22.6 cu. ft. Side-By-Side...
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The bottom half of the fridge/freezer is cool, but not the top half. What's wrong . This is a side by side.
The evaporator fan inside the freezer usually behind the back panel circulates the cold air and blows it into the fridge. Make sure it's running when the compressor runs. And make sure the fan can blow the air into the fridge through the vent.
Sep 05, 2009 | Refrigerators
We had a power outage and top half will not work
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 08, 2009 | Refrigerators
Fridge not getting any air, freezer is working
I have a Kenmore w/ freezer on bottom. The top vent in the fridge is ducted to the freezer and is supposed to blow air. Mine was not.
I removed all the frozen goods and took off the back panel (inside to unit) which had a little ice on it. Underneath the panel was a solid wall of ice......including the motor which is supposed to blow air up to the 'fridge. I'd bet a beer that is your problem as well.
The ice seized motor will not be harmed because it is resistance loaded.
The best part is with a blow dryer and some elbow grease...the fix is free! I hope it helps.
May 27, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Aug 25, 2008 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
