Question about Liquid Video A170E101 Monitor
I need the cable that runs from the computer to the monitor
  • 46 Answers
That's VGA cable you can buy it in local store
Posted on Jun 02, 2010
When I turn it on it runs for about ten minutes. Off and on again it runs for maybe 5, then 3, then 2. What should I look for?
Sounds like power supply or the cable may be bad. Try another monitor on same cable or same monitor on different computer with same or different cable exchanging components until problem stops. It may be the power supply to your computer is getting bad and cannot support the power requirements you need. OR, it may be that the monitor is starting to need internal component, like relays of power supplies for itself. Try the other stuff first.
Hope this helps.
Brock
Sep 16, 2010 | LG W1934S-BN 19" Monitor
Only says cable disconnected on screen
May be your monitor cable has been faulty.You can check it from service center.
Mar 24, 2010 | Dell E551 15" CRT Monitor
Resolution problem with AOC TFT 185W80PF
Monitors don't need drivers to function. Either you need to configure it or it's dead.
Mar 16, 2010 | AOC 19" LCD HDTV Monitor
How do I get the speakers to work. do i need to run an audio cable from the monitor to the computer
Quite simply, yes. There should be an input jack in the back of the monitor. The stereo audio cable for this should have came with the monitor.
Dec 06, 2009 | Balance CM2019 19" LCD Monitor
No sound - looks like I need some sort of cable as the blue plugin in the back is the same as blue plugin in back of computer?
Yes, if your monitor has built in speakers, you will still need a cable running from your computer to your monitor.
Jun 30, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
Looking for the three cables needed for a 17" KOGI L7CH LCD monitor. Where can I find these, please.
You need a signal cable, an audio cable and the power adapter. The first two are standard cables available at any retailer of computers and monitors or online. The signal cable is the type that has 15-pin "D-sub" connectors on each end. The audio cable will have a mini-stereo plug on each end. The power adapter is available from several online sources. There's an eBay auction currently running for the adapter you need.
Jun 15, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Monitor not working with converter
You have to make sure the DVI output of your computer supports analog video.
Check online for a DVI pinout. You will see the group of 4 or so pins to one side of the connector provide analog VGA. If your Video card (or cable) doesn't utilize those pins, then your monitor isn't going to be supplied the signal it needs.
Regards,
-Ben
Nov 18, 2008 | Computers & Internet
USB outlets
I'm assuming you are speaking of the USB ports on the Monitor?
Do you have the USB cable running from the back of your computer to the back of your monitor? For those ports to work, you need a USB cable that runs from the computer to your monitor. This is a cable in addition to the power cable and the video cable. Verify you have three cables connected.
If you are not speaking about the USB ports on the monitor, please advise...
Aug 29, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Please help for Cable and Power supply for KOGI monitor L7EH-TA ???
the power cable is as the simple attach to run the pc..
the vga cable u have to buy it from computer/monitor shop..
ask them for cable by telling them the model and spec. of your monitor.
regard,
dont forget to rate it
Jun 14, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Speaker sound
If your monitor has speakers built in, then you need to run a lead from your soundcard on the computer to a audio port on the monitor. It is normally hidden away near where the video cables etc plug in under the back of the monitor.
Hope that helps. =)
Apr 11, 2008 | Mag Innovision InnoVision LT 565 15" Flat...
Liquid Video A170E101 Monitor Logo
Top Liquid Video Computers & Internet Experts
Marcin
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
