Question about Whirlpool Dryers
HOW REPLACE DOOR SWITCH ON A WHIRLPOOL DRYER RES7646KQ0
  • 56 Answers
You have to remove the two screws in the top but the filter then you literly pri the top up from the front a strong putty nife is good for this then you should see the switch right ther in the top two screw a couple of wires and your done wire for wire though make sure unit is unplugged
Posted on Jun 02, 2010
How to replace dryer door switch on whirlpool model len2000jq1
Rob, I believe I may have answered this in an earlier post, here it is again, 1st and 3rd link, scroll down to how to replace dryer belt videos, it will show how to remove top of dryer and get access to door switch.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My LEN2000JQ1 Model Overview from PartSelect ca
Whirlpool Dryer Model LEN2000JQ1 Switch Door Switch
http://www.appliancepartspros.com/parts-for-whirlpool-len2000jq1.html
May 13, 2016 | Whirlpool Dryers
.Whirlpool electric dryer will not work.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Here is the door switch.
Jan 10, 2011 | Whirlpool WED5200T Electric Dryer
I need to replace a door switch on my Whirlpool Duet dryer. How?!
look toward the bottom the screws are recessed upward to hide them then it should open up like a car hood and there are spring clips at the top
Oct 31, 2009 | Whirlpool GEW9250P Electric Dryer
Our whirlpool 6th sense dryer model awz3413 will not turn on
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jul 21, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool electric dryer (Model # LER4634DQO). Dryer won't come on when we push the start button.
The dryer would not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
4. Timer
Jul 08, 2009 | Whirlpool Dryers
Whirlpool electric dryer runs fine. But when I
To stop it just turn the timer to off intill you can order you a door switch. www.whirlpoolpartssurplus.com... would recommend doing a few tests first...
Jun 23, 2009 | Whirlpool Dryers
My whirlpool dryer will not start
OK, check the following areas to combat this no start issue.
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
If all the above checks out ok, replace the timer or control board.
Jun 14, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool electric dryer LEB6300 door
you have to lift the top cover. then from there you can access the door switch of the dryer.
look closely between the front wall and the top cover. pry the top cover slowly and push the plastic lock that is holding the top cover.
then you can see the switch now and replace.
tnx 4 using fixya,
drcool
Sep 08, 2008 | Whirlpool LEB6300 Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
