Is there a way to hook up my tv sound to the home theater system my system is a insignia dvd cd vcr am/fm stereio combo unit
  • rjmar Jun 22, 2010
    do not understand instructions, they just tell you what it is. i do not understand the functions of the jacks in the back HDN1,in/out, etc. could you explain a common function of the typical function of an audio system
    President:
  • 1,561 Answers
I advice you check the manual of the unit for detail information on the above subject matter,
Take care.
Posted on Jun 11, 2010
Hooking up your surround to your television
Does your TV have an audio output? if it has, then connect that to your Insignia 5.1 ch. audio input.
Jun 07, 2010 | Insignia 5.1-Ch. Home Theater System with...
Hook up tv/dvd
All you need is A/V cable. These are yellow, white, and red. If you have an old model TV that doesn't have these, you can get an RF modulator from any electronics store, which will enable you to connect the DVD/VCR combo.
Sep 16, 2009 | Insignia Digital-to-Analog Converter for...
I can't get the JVC system hooked up with my DirecTV Satellite system where I can use it with my TV and VCR/DVD I tried everything in the manuel please help thank you
You need to plug all the audio "out" of the individual units to the audio "in" on the theater system and change the function/unit switch to the unit you want to listen to. If hooked up this way the theateer system has to be on to get any sound no sound will come from the tv. The easiest way is connect everything to the tv, and if the tv has an audio output jack, plug that into one of the inputs on the theater system. Connected this way anything that comes out of the tv goes into the theater system and you can still get sound from the tv at all times.
May 26, 2009 | JVC TH-G30 Theater System
Hooking up audio video to cable box with home theatre
From Cable Box to Input on DVD Player, from DVD Player Out, to TV in, from TV Audio Out to Home Theater Audio In.
That should work.
Will have to have the VCR on to watch cable. Plus make sure that you use A/V cables as much as possible. Coax works ok, but not as good as R/W/Y.
Feb 13, 2009 | Panasonic Home Theater System System
Hook up to tv
hello there. name is ryan lets see if this helps.
typically in a combination unit there is no rca audio ouputs on the tv. reason being is it is a combo unit not meant to be a item within a home theater system. it has the whole home theater built in it. ;) however if there is any audio output jacks on the tv you should be able to wire the surround sound unit up via rca cable output from tv to input on reciever for surround sound
Feb 13, 2009 | GPX DV7500 System
Hooking samsung htz310 into insignia 52 inch flat screen
From what i learnt you learnt to connect tv to system with hdmi and a  optical lead..
Jan 20, 2009 | Samsung HT-Z310T Theater System
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
Curtis 5.1 Home Theater System
can it hook up to the cable and have the sound can out the speaker when wacth tv . so one can here it with not be so loud for the for any oneself,in the roon with then .
Jan 06, 2007 | Curtis Lifestyle DVD System
13 people viewed this question
 Grubhead
Grubhead
