Question about Vivitar ViviCam 8400 Digital Camera
Unable to download pictures into computer, asking for an"A disk
Never asked for disk before.After inserting SD card it automatically opened the window and downloaded all pictures. never had this problem before. Also have pictures in the internal memory that won't download. Do all SD cards have to be formatted before taking pictures?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 238 Answers
1. Last question first :No, there is no need to format all SD cards every time.
2. Sometimes this happens. I mean sometimes there is a need to format the SD card. Because , may be you use it for other purpose with other electronic items. But if you use it for only taking pictures with your camera then there is no need to format it. When you use it with other instruments then it is better to format the card.
3. You should use one recovery programs to save your pictures. After that you format your card, use it normally as you do before.
Posted on Jun 03, 2010
How do I get my files off of an sd card(for a phone) that neither a phone or computer can detect?
hi this might help, ime not sure but try it, take card out of phone and put it in sd slot on your computer if it has one, if it dose not read the card, then go into windows explorer then computer and see if it is there, if it is then right click on it then press properties this will tell you if the card has anything on it, if it has then press it to bring up the info on the card, pictures and music and all data, hope this helps you...
Dec 18, 2014 | SanDisk 16gb Micro Sd Hc Microsd Memory...
How can i recover the pictures in my SD pro duo memory card which when inserted in my Sony DSC W330 it appears reinsert the memory card which infact it is already inserted? pls help me.,what should i do?
you can recover pictures from sd card with SD Card Recovery Software like asoftech photo recovery, the card recovery software not only recover photos, but also videos, music files and other files. download the software from
hope this helps.
Aug 09, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
I'm using for sand disk micro SD 2GB (NEW) card.the memory card open in my mobile phone(Nokia N73). smooth working.but the memory card not open in my computer. start-menu-my computer-removable...
I've been encountering this issue. The problem may come from the card reader or the card holder. If possible, use a different card holder and of problem persists, try a different card reader or test on another computer.
Hope this helps!!
May 08, 2011 | SanDisk 2GB microSD Memory Card
PNY micro small piece inserted in mobile phone and adapter to the computer, but not copy mobile phone pictures to the computer.
for reliability buy a dedicated micro sd reader as not all the adapters work.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | PNY 2GB microSD Memory Card
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
I'm unable to format my 4gb Sandisk High Capacity SD card. The response I'm getting is that the disk is write protected.
Hold the SD card so the label is upright and facing you. Locate the switch on the left side and slide it up to unlock it. If you have a Micro SD card, put it into an SD card adapter. Slide up the switch on the adapter to unlock it.
Insert the SD card into your computer. If you do not have a built-in SD slot on your computer, then connect it with a USB adapter.
Open the Computer icon on the desktop. A window will open with a list of the available drives. Locate the drive the represents the SD card. The name of the drive may differ depending on you named it, or what the default name is.
Right-click on the drive and select Format. If it asks what you would like to format it to, select "FAT32" and click Start.
Oct 23, 2010 | SanDisk 4GB microSD High Capacity Memory...
Unable to open my pen drive
try formatting. if not then replace it
Aug 06, 2009 | Transcend (589307) Media
It doesnt work when i insert the card with my micro memory card and asks for a disk
Hi likkle_miss_,
The Micro adapter has no memory in it. It is just an adapter to use so you can plug your Micro SD memory card into a larger (SD) slot. The SD Micro memory card needs to be inserted into the adapter.
Kingston Tech Support
Apr 22, 2009 | Kingston 1GB Secure Digital Memory Card
UNABLE TO VIEW PICTURES
no disc for these cams...should be able to view pics straight from SD card thru a card reader to pc...(may have to go thru START..MY COMPUTER...LOCATE DRIVE CARD READER IS DESIGNATED AS....
also should be able to view pics on tv thru video cable attached to cam.
Jan 24, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Computer won't read memory stick
SCMG - You won't be inserting it into your modem. But if the card fits snuggly and it seems to fit right, then you're probably where you need to be.
For all of you - it may be easier to connect the camera directly to the computer to download the pictures. All cameras come with the appropriate cable to connect the camera to a USB port. All you need to do is make the connection and then put the camera into "review" mode to view the pictures and Windows should automatically see the camera and ask if you want to download the pictures off of it.
Jan 07, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Vivitar ViviCam 8400 Digital Camera Logo
75 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
