AC Not coming out of vents enought to cool - Heating & Cooling
  • Brian Niten Jun 03, 2010
    I'm not sure what you are saying. Is there not enough air coming through the vents or is the air coming throught the vents not cold enough?
  • bepritchett Jun 03, 2010
    Not Enought Air
  • 674 Answers
First thing you should do is check/change your air filters and check the indoor coil and make sure they are clean. If that doesn't make a difference then check your fan and see if you think it is running fast enough. A weak capacitor can cause a fan to run slower. Also check the fan and make sure it is clean. Let me know if you need more help.
Posted on Jun 04, 2010
Testimonial: "Thanks,I'll try to check the things you suggested."
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jun 03, 2010
What is an engine cooling fan...can you feel it come through the ac vents?
The engine cooling fan is located on the front of the engine between the radiator and the engine block. You do not feel it through the ac vents.
Jan 24, 2015 | 1999 Buick Riviera
Heat comes tru passengers side console vents and normal thru drivers side
look under dash to make sure vent door is working proper
Apr 20, 2014 | 2010 Ford Flex
M for my nissan quest 99 is not working at the back of the van and is not cool enought for all car
sounds like your mechanic is just a oil changer and not a skilled technician,your Ac system needs draining on a proper machine and the amount of gas recovered weighed,then a vacumn and a additive for stop leaks added with some leak dye and the system regassed and this vehicle if the same as a nissan cargo or serena with rear AC unit should hold somewhere around 1.4 kilos of R134 gas ,note its in kilos not lbs and this is by weight not one of them cans from the local wallmart connected to the inlet port ,then when the gas is added check the pump pressure with the machine on the high pressure port ,then close the valve and allow the inlet port to draw the gas back into the system then when machine is disconnect you check the amount of gas on a recovery to make sure all the gas went into the vehicle if more than 20 grms recovered from the machine then allow it to draw some more in via the inlet port .
Apr 08, 2012 | 1999 Nissan Quest
I have a parc model..36 foots, my ac is not cooling enought.i wont to kow i much btu is my ac..mod:59516-531. tank you
15,000 btu. Has it been cleaned well recently? Quite often that is all that is required. Has it never cooled sufficiently?
Aug 30, 2011 | Dometic Rooftop RV Air Conditioner
Passenger ac vent cools and driver side ac vent do not
It sounds like a heater blend door issue inside the heater box that is actually not closing all the way to allow either cool or hot air or visa/versa.
Sep 07, 2009 | 2004 Toyota Land Cruiser
Ac not cooling well - noticed 2 days ago steam coming out of ac vents.
That was probably not steam but escaping freon coming from the vents. Probably the best course of action would be to take it to an AC repair shop.
May 04, 2009 | 2005 Dodge Grand Caravan
AC is not cooling
I would say you have a freon leak. May be the outside unit is not running now because the low psi switch has it off because it does not have enought freon.
Apr 07, 2009 | Haier Air Conditioner
07 ranger stx a/c problem not blowing enought air
hi one of your plastick vents has come of your main vent please check that all vents are ok in there right spots cheers peter
Jul 21, 2008 | 2007 Ford Ranger FX4 Off-Road
Ford F150 AC Problem
there is a vent opening linkage for the top vents if you had removed panel for sterio install this linkage might have come loose or the wiren to electric relay to open top vents came loose
also vent doors on front of a/c vents are turned to the closed position
also quite possible the passenger blower motor compartment door in side the blower mode has something blocking entrance
also your truck might be equiped with a blower motor filter i read that these need to be changed out during normal filter replacements the filters for ford i didnt know they started using filters for a/c on reading this since 2000
May 31, 2008 | 2003 Ford F150 Regular Cab
Heating & Cooling Logo
99 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
