Question about Philips ProScreen 4650 Multimedia Projector
I see three of everything
When i turn on my device the letters and designes are three times on my screen instead of just one (i see three aof everything)
Keeps coming up don't recognise my email address. I joined up on on my tv. Three days. Age. Now I'm on my iPad
It can only be that your email address on one device is different to the other device. One letter, number, or a comma instead of a period will cause it to fail.
andrew.taylor@ is not the same as andrew,taylor@ all because of comma used instead of a period, and yet it looks the same.
Jul 31, 2017 | Computers & Internet
Dell latitude D630 When I turn on my laptop the lock icon with the A inside it is flashing. It will flash a couple of times then everything will turn off. The screen is blank the entire time. Any...
This indicates when the uppercase letter function is enabled.
See the manual here http://downloads.dell.com/Manuals/all-products/esuprt_laptop/esuprt_latitude_laptop/latitude-d630_User%27s%20Guide2_en-us.pdf
Page 99 says the three LED indicators for Num Lock, Caps Lock, and Scroll give the POST error status, and the reason for not starting up. Then contact DELL customer service for assistance.
Check these and then contact
Feb 27, 2015 | Dell Computers & Internet
Countif formulas
Are you trying to find how many don't have a letter? If so you might try "COUNTA" instead of "COUNTIF". You could also try looking at the format of the cell your formula is in and change it to general or number.
Jul 13, 2014 | Computers & Internet
Hello, my Huawei ascend y300 has a problem
I know of no camera with a keyboard - are you sure you have posted this query in the correct forum ?
May 22, 2017 | Cameras
When I plug in my s1 the watch just turns on instead of going to the charging screen. How do I get the charging screen?
I have had the same problem, but got round it by first powering off the watch, then waiting a minute or so. Then I attach the clip, having made sure I have the pins exactly aligned before I let them touch the contacts. Even so, a slight wriggle might be necessary to get them properly seated. I get it to work one time in three this way - what a daft bit of design!
Jul 30, 2013 | Garmin Approach S1 Golf GPS Watch
Asus p5gc mx sata drive very slow integrated with ide dvd drive, also odd drive letters
You can try checking device manager drivers in safe mode or under view > hidden devices. This will show extra devices and errors. The odd drive letters don't matter at all. You can always change in Disk Management, but be aware of anything pointing to particular drive letters.
Aug 24, 2012 | ASUS P5GC-MX/1333 Motherboard
How do you change the text message settings to TAP instead of Abc
How to set up Text Entry Mode?
1. From any text entry screen (ie. when you are writing a text message), press the top center button, the one above the directional wheel.
2. Press on "Entry SetUp"
3. Select the "Primary Set Up" or "Secondary Setup" by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
  • ITAP: it's a built-in software which predicts the word you are typing.
  • TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter "F" press the number 3 button three times.
  • Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
  • Jun 11, 2009 | Motorola Mobility RAZR V3
    Vista - Time executable not working
    try uninstalling your printer if you used a disc and use the plug and play
    Nov 11, 2008 | Computers & Internet
    Maxtor basics personal storage 3200 shows up as a usb mass storage device with no drive designation letter. used to work but not after problem with win xp pro & reloading oper. syst.
    press the "Start" and "R" keys at the same time.
    type "compmgmt.msc" in the box and select OK.
    On the left pane, select "Disk Management"
    on the screen, look for the drive that does not have a letter.
    Right click the bar (on the bottom part of the screen) of your drive and select "Change Drive letter and paths...".
    Click add and select the "assign the following...".
    on the drop down menu, select any letter you like EXCEPT A or B.
    click OK.
    Your drive should now show up in My Computer. All of your Data should still be there also.
    Aug 23, 2008 | Computers & Internet
    Philips ProScreen 4650 Multimedia Projector Logo
    54 people viewed this question
    Top Philips Office Equipment & Supplies Experts
    jasbo
    jasbo
    matt martin
    matt martin
    Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
