Question about Worx 10" 18v 2 In 1 Grass Trimmer/In Line Edger
Will not start
When I pull the trigger nothing happens. I've had this trimmer a little over 2 years and all of a sudden it will not start up. I replaced the spring on the safety switch and I know the battery is charged up as I also have a worx trimmer. I don't see any lose connections. What do you think it might be?
    President:
  • 2,702 Answers
It could be the motor brushes worn out
Posted on Jun 02, 2010
Testimonial: "hadn't really thought of that. I'll check that out. Thanks."
    Problem Solver:
  • 4 Answers
Took mine apart and all it does is run for a second and quit,battery show 24v at the terminals?
Posted on Apr 19, 2013
Electric hedge trimmer want run why?
electric hedge trimmers have 2 switches to press before it runs
one is the trigger that you pull and the other is in the handle that you hold in your left hand
both have to be on before it starts
it is a safety feature to stop operators cutting off their fingers
Jun 09, 2016 | Little Wonder 2230S 30 Single Side Hedge...
25hp pull start cord not retacting spring has been replaced
When fitting any pull start spring, you must first pre wind the spring. Once the spring has been at least 1/2 way wound up or tensioned, wrap the pull rope around the spool. When you assemble it and pull the cord, the spring should wind up further to its fully wound position and now retract as normal. If you don't prewind the spring, there will be little or no tension to rewind the rope.
Sep 25, 2014 | Garden
Just quit working one day, drill is just over a year old not used a whole lot, pull trigger and nothing happens
Are the batteries fresh? How about the switch? Is it in the right position? I can't believe the motor has died. Even a dead battery will spin it a little. Check that out and let me know what you find.
May 03, 2010 | Dewalt DC910KL Heavy-Duty 1/2" 28V Nano...
The spring placement for the trigger replacement
Look at the old trigger and see where the spring has been rubbing. Place the spring around the trigger post and slide it into the trigger housing. With help of a small screw driver or scribe to flip the trailing end of the spring over the stop post in the housing. Hope this helps
Sep 04, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Engine starts but dies when I pull throttle trigger
you need to adjust the high speed needle turn it out in 1/4 increments as you throttle it, low speed may have to come out alittle but do high speed first. I had to answer this as I use to have a pastor john in sturgeon bay, miss him alot.
Jul 22, 2009 | Ryobi Garden
Wont start
try and change the solenoid!!
May 23, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Craftsman 32cc Line Trimmer pull start will not engage engine.
Hi I have a craftsman 4 cycle model no. 316.791970 gas trimmer. When I pull on the rode there is little resistance . I took the sparkplug out and put a flash light down the hole and there is a thing that is moving . What should I look next, or do you know what is wrong? Thanks for any help! I've had it only 3 years and already Sears have replace the clutch assy.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Worx 10" 18v 2 In 1 Grass Trimmer/In Line Edger Logo
730 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Jay Finke
Jay Finke
Are you a Worx Garden Expert? Answer questions, earn points and help others
