Question about Microsoft Xbox 360 Console
Xbox 360 DVD Drive ONE red light
I have an Xbox 360 that needed a DVD drive so got one from a friend and it WAS working in his but now that I put it in mine I am getting ONE red light. When I take it back out the red light goes away. What would cause this problem and how can I fix it? Like I said the DVD drive works in his but not mine...
    Scholar:
  • 161 Answers
The DVD drives are not interchangeable. Each one has a code that it matches with the motherboard when those numbers do not match they will show you the one red light which is known as a "general hardware failure".
You must do somehting called xbox 360 DVD Drive Spoofing. In order to cover this it is wayyyyyyy too much to type here. Here is a link that will help you.
http://www.360-hq.com/xbox-tutorials-61.html
Posted on Jun 02, 2010
Hello my problem is in xbox 360 elite e 73 one light red
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 28, 2011 | Microsoft Xbox 360 Console
Xbox-360 elite lower right hand red flashing led light code error E73
Jan 17, 2011 | Microsoft Xbox 360 Console
Xbox 360 one red light bottom right
Nov 05, 2010 | Microsoft Xbox 360 Console
Got a green light in the centre and bottom rt is red,can`t do a thing with it,any ideas?
When only 1 of the 4 green lights that are located around the start button flashes red and the screen flashes an error code number, it means that you've got the Xbox 360 1 red light message.
once you have found out if its the hard drive or the dvd drive then this is the part that needs replacing.
you will either need to get someone to do it for you or if you have some idea what you are doing then it is something you can do yourself, always check to see if you have any warranty left and if you do take it back if not then you will need to pay someone to do the work for you.
if you are doing it yourself then take it from me its not easy taking the case off let alone changing the parts so if you are going to do it yourself use google and fine an xbox 360 repair guide and this will then give you step by step instructions on taking the case off and removing any parts you need to remove
Sep 16, 2010 | Microsoft Xbox 360 Console
My 360 will play movies all day long, but when I put a game in it plays for approximately 3 minutes and shuts off. The lights on the left side of the power button flash red. What is the deal?
Sep 15, 2010 | Microsoft Xbox 360 Console
Xbox 360 DVD drive
Take out the dvd drive and then turn on the power to see if the one red light comes on. If it doesn't come on after taking out the dvd drive then that means the dvd drive is shorting out the main board.
If you take out the dvd drive and the one red light still comes on, then that means its a problem with the main board and your 360 would need to be serviced.
Jun 01, 2010 | Microsoft Xbox 360 Console
One red light on xbox 360
In most cases If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages.
HERE IS THE RED LIGHT REPAIR MANUAL: http://docs.google.com/viewer?url=http%3A%2F%2Fpdftown.com%2Fpdf-ebook%2FXBOX%2520360%2520Repair.pdf
Oct 19, 2009 | Microsoft Xbox 360 Console
Xbox 360 samsung m25 game fault
It's Not The dvd drive key otherwise you'd get the three red light lights. It's most probably a bad firmware flash try and reflash it to the original firmware with the same dvd drive key and see if that works.
Alex
Jul 10, 2008 | Microsoft Xbox 360 Console
Xbox 360
The dvd rom drive is probably not functioning properly maby try to use the drive out of you friends 360 or have your drive tested.
Jan 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
121 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
