Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The remote for my garage door only works on weekends.
The remote for my garage door will not open the door Monday morning through Friday afternoon. Friday night through Sunday it works fine. This is also happening to a neighbor two houses down the street. this has been going on for about four weeks.
    President:
  • 3,197 Answers
Monday through Friday look at the LED on the rear of the motor unit. If it is flashing rapidly you have radio interference. See if you can locate the source. It will be something electrical - maybe a military base if nearby.
Posted on Jun 02, 2010
We installed the opener and everything works as it should but every morning we find the door open. Then in the afternoon it usually closes itself.
i would look for a shorted out wire to the wall button. maybe a staple thru the wires shorting it out. cold night and warm days expand/contract wires and staples and make a connection.
Apr 29, 2015 | Craftsman 1/2 HP CHain Drive Garage Door...
Photos@vizio.com/Casenumber/2540322
My tv has white lines across all on the screen
Jun 05, 2012 | Vizio 42 in. LCD TV
Remote and garage door opener not communicating. It worked fine on Friday morning but by Friday afternoon it wouldn't work. The keyless entry had to be programmed and now that's how we're...
You may need to replace the battery in the remote control. Most usually these will be double A ones. You may have to reprogram it when you try it again. You should be able to get the information on Google by typing in the make of the inside unit in your garage. Your remote may have this info on it as well. You should be able to pull up instruction on how to reprogram your unit.
Sep 15, 2017 | Chamberlain 1/2-HP Whisper Drive Belt...
Garage remotes and keypad don't work in the morning!
Something in the receiver portion of the logic board has become sensitive to cold. This is not uncommon in electronics. The sensors are working as they should and the wall control is hardwired and doesn't use the receiver. A new logic board is the repair. The lights are normally a simple repair. Unplug the unit and pull out on the center contact of the light sockets.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Remote Openers Stopped Working Suddenly
Check the wall control. If the small green light is blinking press and hold the button with the lock icon for 3 seconds.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote only closes the garage door, will not open it
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
In your case the expansion of the wall in the afternoon may be enough to cause pressure on the wire to increase the problem – works in the morning but not the afternoon.
Also after you change the batteries you need to reprogram the remotes.
HOPE THIS HELPS
Aug 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
108 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
