My upc remote control has stopped working completely even though i have put new batteries in it. the remote doesnt even light up when i press the buttons.
SOURCE: My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Posted on Jan 01, 2009
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Posted on Mar 30, 2009
  • 6 Answers
SOURCE: my remote control for bush tv A642F stopped
Try keeping the handset menu button pressed for abount a minute, then check the other buttons again, this sometimes works - the set software seems to 'lock-up' causing this problem.
John
Posted on Dec 20, 2010
SOURCE: RCA Universal Remote stopped working
I also have the same problem with my rcv remote and it started when the batteries accidently feel out
Posted on Feb 05, 2008
ktkodama
  • 37 Answers
SOURCE: Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Posted on Jan 20, 2009
My tv remote .It just stopped working.I put new batteries .Why.Two adults in home .Why would a remote stop functioning!!!???
Why is my remote not working?
To determine which of these conditions is causing your problem, follow these steps: 1) Open the battery compartment on the back of the remote and remove both batteries. 2) Press and hold any button on the remote for 20 Seconds. 3) Release the button and reinsert the batteries properly.
How can I solve if the remote control is not working? - Samsung
www.samsung.com/sa_en/support/skp/faq/239888 Search for: Why is my remote not working?
Why would remote stop functioning Google Search
Dec 09, 2016 | Televison & Video
Tv remote wont work even though new batteries are put in.cannot change channels or volume or even turn the tv off or on
Try opening up the unit and cleaning the contacts and bottom of the buttons with a q-tip and a bit of rubbing alcohol. Over time the oil from your fingers gets inside and creates a film between the contacts and the button so the circuit will not complete and your buttons stop working.
Feb 17, 2015 | LG RU-42PX10 42 in. HD-Ready Plasma...
Philips htl2100/12 soundbar doesnt respond to remote control after plugging in
My soundbar won't power up. So I pull the battery out of remote, press a few buttons, put the battery back in and all of a sudden the device can be powered up and controlled. Until next time it stops responding. I replaced that original battery with a new one but the problem still persists.
Dec 10, 2013 | Philips SoundBar DVD Home Theater with...
Remote has stopped working
purple_mochi
Even though the buttons illuminate on the remote, it may not have sufficient power to actually operate the receiver commands. Replacing the batteries may solve your issue. If it doesn't, then readdressing the remote to the receiver should resolve the issue. I have provided instructions on how to readdress. I hope this helps.
Remote: All Other Remotes
  1. Go to System Info screen
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Ray Calo
DISH Network
Jan 20, 2010 | DISH Network IR Remote Control
Harmony 550 remote - buttons not working
Hey!
Unfortunately most things you need to do would require access to the Harmony Remote Software. However, the only advise I would have is for you to remove the batteries and try putting them back in.
Sorry I couldnt be more helpful...
-Kennedy
Dec 25, 2009 | Logitech Harmony 550 Remote Control
The remote just magically stopped working, even after new battery
Have you tried pressing the 'input' button again this time to switch from video to tv? This happens in quite a few cases where 1 remote is used for many products. Please try and let me know.
Aug 21, 2009 | Televison & Video
Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Aug 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Battery died and need to set up codes for Fisher TV
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3021
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For replacement remotes visit www.sparky-uk.com)
Jan 06, 2008 | One For All URC-3021 Remote Control
Remote
Try taking the batteries out of the remote, then pressing the power button on the remote for 5 seconds. Then replace the batteries. This should have reset the remote and should work.
Dec 31, 2007 | Durabrand DWT1304 13" TV
Televison & Video Logo
853 people viewed this question
Top Televison & Video Experts
Electro Med Services...
