Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Everything in the freezer forms ice inside the packaging
  • Whirlpool Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratoreverything in the freezer forms ice inside the - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 04, 2010
Ice forming on bottom of freezer.
is the drain tube plugged up that drains defrosted water to the bottom pan,its located behind the inside rear panel just below the evaporator
Feb 07, 2013 | Refrigerators
Why do i have frost on the inside?
frost forms from either the door being left open,a ripped gasket,when warm and cold air meet frost forms,also if the back inside wall of the freezer is frosted up you could have a defrost problem,bad defrost thermostat,heater timer or board depending on the model number.if the warm air got in say overnight you could have a problem with the fridge not getting cold,usually the air ducts freeze up.if it's in the freezer look at the door,you might find ice on the door where the warm air was coming in and also you'll see frozen water droplets on the packages and walls
Sep 02, 2012 | Refrigerators
Have PSS25MGMBB The freezer not staying cold and forms frost on the inside of the freezer compartment wont even keep ice frozen
sounds like the defrost heater might be going out, you can order a new one at marcone.com with your model number, very easy to do. You will want to have the unit unplugged for a day or so before you do it, all frost should be gone before you start
Jun 10, 2012 | GE PSS25MGN Side by Side Refrigerator
Food in my freezer is icey. ice is forming inside unopened package
is the door closing properly, we had a similar problem with an old freezer, the seal had gone in one corner and air was getting in which just caused masses of ice build up. hope tis helps
Apr 05, 2012 | Kenmore Refrigerators
Freezer is running constantly. ice crystals formed on outside of packaged foods. food is still frozen.
the door was left open,if you find frozen water droplets on the food packages or ice crystals it forms from the warm air coming in,make sure all the packages are pushed in and not hitting the door and you can tilt the fridge back a little so the door will close with a slight push.also check the ice shout door and make sure no air is leaking through it,you'll know you'll see all ice around it.you can check the condenser coil and condenser fan to see if it needs to be vacuumed,the machine will run longer if the coil is clogged with dust or if the fan isn't blowing,the coil should be cleaned every 6 to 12 months.hope this helps but it sounds like the freezer door was left open.
Sep 06, 2011 | Frigidaire FRS23KF7AB Side by Side...
MY FREZER HAS FROST AROUND THE DOOR AND MOLD IS GROWING AROUND IT
You need to replace the door gasket. It's leaking air causing the frost.
May 04, 2011 | Whirlpool Freezers
Icicles forming from melting ice from ice maker
hi this might help you:
*make sure that the seal indeed still seal well enough...
*the older the fridge the more common this is
i don't really know much about this, but just check that it's cold enough inside like check if it changes when you change it from eg 4 to 7, and that the sealing is fine, and that your door is lined out good, also important that last thing offcourse, cause if it seems to shut good, but the seals arent in the right position compared to the other side (the 'fridge-walls' :p) they won't seal ofcourse...
I hope this is useful, and greets.
Oct 20, 2009 | Refrigerators
Ice forming in freezer
Un-plug refrigerator,remove the back panel from freezer section and see if ice is covering coils. If so, probably the defrost heaters are blown.
Feb 23, 2009 | GE Refrigerators
Layer of ice forming on bottom inside of freezer - Samsung fridge freezer
might have the temperature too high .. buy a freezer thermometer and place in freezer
Jan 20, 2008 | Freezers
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
42 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
