Question about Nokia 6120
Sending Fax Phone can establish a data call using PC (USB or BT). How do you get PC to establish data call to send fax - are ther AT strings?
  • 48 Answers
Make sure you phone support fax.
if support you just pair it with pc and it should have install phone modem driver. used the modem as your fax out line.
Posted on Aug 16, 2008
  • lixdo
    lixdo Aug 16, 2008
    *** Please give good rate to my solution ***
I need to connect my fax whit the magicjack
A voice over Internet protocol device, magicJack allows you to make and receive telephone calls from your computer using a USB device. While magicJack does not officially support sending and receiving faxes, you can connect a regular fax machine to the magicJack device to send and receive faxes.
Attach the magicJack device to a USB port on your computer.
Connect the phone wire to the port at the end of the magicJack device.
Connect the other end of the phone wire to the "Input" jack on your fax machine.
Turn off error correction on your fax machine, and set your fax machine to the lowest possible transmission speed. Consult your fax machine's user guide if you do not know how to turn off the error correction or lower the transmission speed on your fax machine.
Send a fax to your magicJack phone number to receive a fax. You can find your magicJack phone number at the top of the magicJack splash screen that will display on your computer after inserting the magicJack device.
Send a fax from your magicJack by loading the fax you want to send into your fax machine and pressing the "Send" button.
Oct 31, 2016 | Computers & Internet
Can't send fax using windows 7 fax and scan the fax cannot be sent
Hi again. is the handshake being performed? can you hear that fax scream from both ends of the connexion?
If you them the connexion has been established..in that case there may be something wrong with the transmission phase of the software you are using
TRY A DIFFERENT APP.....IS THE SOFTWARE YOU ARE USING WINDOWS 7 COMPATIBLE.
I would also check to ensure that the system requirements of the app you are using are met
Feb 28, 2014 | StarTech.com Startech USB DATA FAX MODEM...
Sending a fax with my mac
Most Mac's no longer have a phone modem connection. Fax is the act of sending data over a phone line. If you need to just send a fax over the internet there are a few online solutions, and a quick search in the Mac app store gave me iFax Send Receive Faxes free, but with in app purchases. Good luck.
Jul 09, 2012 | Apple Computers & Internet
HOW TO SEND FAX INTERNATIONALLY
Sending a fax to another county is easy - almost as easy as sending a fax to someone in your own country. The only difference is the phone number that you'll dial.
When sending a fax from one U.S. city to another, you dial a 1, then the area code, then the seven-digit phone number. When sending a fax from the U.S. to another country, you usually dial 011, then the country code, then a city code (which is like an area code), then the phone number. (The phone number isn't necessarily seven digits.) Check out the web site www.HowToCall.info, which will give you the specific country and city codes for the place that you're trying to send a fax to.
Other than figuring out the phone number, faxing internationally is identical to faxing domestically. Fax machines in other countries use the same protocols as ones in the United States, so you should have no difficulty communicating with a foreign fax machine. Older fax machines and noisy overseas phone lines may cause the transmission to take a bit longer than you're used to, but it should get there.
The first time you send a fax to another country, it might be a good idea to listen in as the fax machine dials. On some fax machines, you can press the "Dial" button to hear the dial tone, and dial the number manually. Listen for the ring and fax tone, then press the Start button to send the fax. You might want to do this the first time you send a fax overseas, just to make sure it's working as expected.
Oct 06, 2010 | Office Equipment & Supplies
Winfax Basic
If you have the fax # correct, than it is the responsibility of the fax recipient to correct the situation. You cannot make a parametrical changes to someone elses fax machine. Thank you, Dana
Jan 18, 2010 | Symantec WinFax Pro for PC
Is there a fax number for people to fax you?
Yes,
It is the phone number assigned to the phone line you plugged into the fax machine. You Fax machine is basically a Modem listening to the phone line. Someone dials and if they are sending a fax, the two machine's make squealing noises called a "handsake" then connect sends data.
It is then stored or printed or both.
If you pick up the phone while the two fax machines are connecting.
You will most likely disconnect the data transfer and get an ear full.
Hope this helps!
Nov 17, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Do you need an extra phone line for a fax on your printer
it depends on what type of printer you have...i actually have an HP officejet j3500 series, it a fax, printer,scanner and copier in one.. when im using it for sending fax messages, i just dial the number where im sending it and it automatically faxes (phone keypad and handset is included)... and i use it as my printer too so its already connected to my pc..so easy to use...
but but but... i actually connected a separate phone line (our original phone from our provider) to the hp j3500 series cuz sometimes i need to speak first to thr person im sending fax before i send the message... i think that is for manual sending of fax...
so if you want to send manually (speaking first to the person before sending) a separate phone line is required (connected to ur fax)
but if u want autofax, then i dont think its necessary...
there u go...
visit this website to learn more.. hope this is useful
http://h10010.www1.hp.com/wwpc/sg/en/ho/WF05a/18972-18972-3328064-3328083-3328083-3440951.html
Sep 10, 2009 | Lexmark X2470 All-In-One InkJet Printer
A particular business can receive faxes from me sometimes, but other times I get a strange beep and it doesn't go through. They receive faxes every day with no problems. I send faxes every day with
This is a problem on ther side. A lot of high volume companys dont admit this, insurance order etc most use pc based fax products to filter junk this can also cause probs
May 11, 2009 | Brother IntelliFax-2820 Laser Fax
Please help me send a fax on my HP 5610
Send a fax
You can send a fax in a variety of ways. Using the control panel, you can send a blackand-
white or color fax from your HP All-in-One. You can also send a fax manually
from an attached phone. This allows you to speak with the recipient before sending
the fax.
If you frequently send faxes to the same numbers, you can set up speed dial entries.
For more information on setting up speed dial entries, see Set up speed dialing.
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Sending and receiving faxes
Do you have an analog phone line or are you trying to run it through a PBX system? I was just having this discussion with RKS tech support. Their fax software was hanging up as soon as the connection was established and all I had available was a VOIP phone line. It took 4 tries but I found a US Robotics fax/modem that worked fine in class 2.0 mode.
Nov 10, 2007 | OKIFAX 5650 Plain Paper LED Fax
Nokia 6120 Logo
169 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
