Question about Maytag Heating & Cooling
Maytag M7Y15F2A-D A/C - won't turn on -long beep then nothing
Maytag M7Y15F2A-D Air Conditioner - got out to put in window - plug it in - get one long beep - then nothing - no lights no anything????? help?took filter out, and retried - same thing???? help?
Thanx KE
  • 4141 Jun 02, 2010
    Maytag M7Y15F2A-D Air Conditioner - got out to put in window - plug it in - get one long beep - then nothing - no lights no anything????? help?took filter out, and retried - same thing???? help? Thanx KEoutlet is working, I checked it before writing
    no power of any kind in unit - except one long beep sound when plugged in - then nothing
    unit has touch controls - tried all buttons already - they produce no response as well
    I took face of control panel off - blew it off with dust off - retried unit- still no response
    pressed all buttons from timer to heat/cold to on/off to mode to fan controls - still no response
    I cannot turn compressor on or change any heat/cold settings...
    any other thoughts?
    thanx ke
  • 4141 Jun 03, 2010
    still not working?
    thanx ke
  • 10,319 Answers
The beeping might be an alarm that indicates the coils are iced over by too much humidity in the air...and/or the unit is overheating etc.
shut off power to the unit for a few hours, go out somewhere if it is too stuffy inside.. see if the unit operates better when you return... I also suggest not running these things constantly, this causes some units to ice up and **** up the power..
hope the unit does get replaced, newer ones are more efficient.
Posted on Jun 03, 2010
I had the same problem and was ready to consider it dead, but I found a last minute fix. The power cord on my unit appears to be picky with my wall outlet. The slightest wiggle causes the power to be cut off. I found that plugging an extension cord or power strip into the outlet, then plugging the AC into that fixed the problem. It powered up and stayed on.
Posted on Jun 04, 2013
  • 3,083 Answers
Make sure that the electrical plug is not wired backwards (positive to ground, negative to positive post). If that were the case, you would get a warning beep, and the unit would not come on. Not having a manual, this is one thing to check first. For non-polarized devices, it doesn't matter about the outlet or device wiring, but many things are polarized these days and the electrical feed has to be correct. Good luck, and hope this helps.
Posted on Jun 02, 2010
  • 4141 Jun 03, 2010
    Good thought but same outlet as last year - no changes made?
    so that isn't it...
    thanx ke
  • Tom Carson
    Tom Carson Jun 04, 2010
    Has this unit been in storage, and how long? I was just thinking about it- you're getting a microprocessor error, which can mean a lot of things. Your manual might give you a hint in the troubleshooting guide, but I suspect that possibly the compressor has siezed up, after being in storage, or maybe oxidation has eroded some relay contacts, things of this nature. You can spray electrical contact cleaner on switches and relay contacts, however, you have to take the relays apart to access the contacts, and they sometimes require a good scrubbing with fine emory cloth, etc. One things for sure, and that is the startup process is being stopped. This unit will have no easy answer, and have to be troubleshot to determine the problem, step by step (point to point electrical, and then analyzed). Hopefully, someone else has encountered this problem, and there is a simple "fix", but the chances seem pretty low.
  • 857 Answers
Step1 Check that the power cord is securely plugged into the electrical outlet and that the power switch is in the "On" position.
Step 2 Plug another device into the electrical outlet to ensure it is working. If the other device does not work, check the fuse box for a blown fuse or tripped circuit breaker. Replace the fuse and reset the circuit breaker as needed.
Step 3 Wait for the air compressor to turn on if you shut off then turned on the air conditioner quickly or if you quickly switched the temperature control to a warmer setting and then a colder setting.
Step 4 Turn the temperature control to a colder setting. If the room is too cool, the sensor within the air conditioner will not start the compressor until the temperature control is set to a colder setting.
  • 4141 Jun 02, 2010
    thanx for the quick reply but this does NOT help?
    any other thoughts?
    thanx ke
  • Jayant Jha Jun 02, 2010
    Step 1
    Check the thermostat on your Maytag air conditioner and make sure it is in the cooling position. Also make sure the thermostat temperature is lower than the ambient temperature in the room. Do not guess at the temperature in the room; use a thermometer to be sure. Reset the thermostat temperature to at least three to four degrees lower than the temperature in the room, then listen for the fan to come on.
    Step
    Make sure there is power flowing to the electrical outlet. Unplug the air conditioner and plug another appliance into the receptacle. If there is no power flowing, check your electrical panel for a blown fuse or a tripped circuit breaker. If power is flowing, continue your troubleshooting steps.
    Step
    Check the condensate pump if your air conditioner has one. If the condensate reservoir is full, the unit may not come on. Empty the reservoir, power the air conditioner on and off and check to see if the fan is running.
    Step
    Check the condition of the filters. If the filters in your air conditioner are blocked, the unit may run poorly or not run at all. Before you call in a repairman, make sure you pull the filter and check its condition. If you have an extra filter on hand, replace the filter with a new one and see if the air conditioner starts to run. If no extra filters are available, carefully clean your existing filter and try to start the air conditioner unit.
No power to thermostat
First check the safety of the air conditioner in the electrical panel of the house, then Check if the socket has power that you put the extension cord and placed an interference power from other priza.an everything is OK then something is going to board the air conditioner
Oct 19, 2011 | Maytag M7Y15F2A Air Conditioner
Not cooling - M7Y15F2A-B
have you done adjusting the thermostat settings & changing the mode settings..?
Jul 27, 2008 | Maytag M7Y15F2A Air Conditioner
What is the maytag#m7y15f2a Air Conditioner worth used
could not find your item online, whats is the BTU, and also the power supply, and age. Thats all you really need for pricing.
Mar 15, 2011 | Maytag M7Y15F2A Air Conditioner
My air conditioner turned itself off and now the display reads EE we have unplugged it it runs for a little while then shuts itself off again
Remove the unit from the window,and dissassemble and use a water hose and clean the inside of the unit,remove all debris,this is most likely the problem.
Jul 10, 2010 | Maytag M7Y15F2A Air Conditioner
Not cooling - M7Y15F2A-B unit compressor not on
Here is a tip that will help you to troubleshoot your A/C unit..
Air Conditioner2_bing.gif Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Apr 13, 2010 | Maytag M7Y15F2A Air Conditioner
Punctured an air-conditioner Freon line
when the freon is released from the unit,you have to repair the leak,pull a vacumm to rid any moisture in system then refill with freon,if you dont have the equipment,it would be cheaper to just replace the unit
Nov 09, 2008 | Maytag M7Y15F2A Air Conditioner
No power surge
first try to clean the unit, if the problem was still there and does not give a cooling, now the unit must have to be filled again with a preon, this could be nothing in there and to be replace..
Kenmore Window unit 15,100 btu, Model 25372156200
with the hum noise sounds like you have a bad fan motor
May 26, 2008 | Maytag M7Y15F2A Air Conditioner
I was having the same problem....take off the display plate to see the mother board....take out the five screws....UNPLUG FIRST!!!!....tHE WIRE GOING FROM THE THERMOSTAT MAY BE UNPLUGGED...IT'S A LITTLE TWO PRONG PLUG PROBABLY ON THE LEFT HAND, MIDDLE
Jun 19, 2007 | Maytag M7Y15F2A Air Conditioner
Heating & Cooling Logo
638 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
