Question about GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS
The ice chute for my GE fridge model PS123SGMD is blocked by a round black flap. How can I remove the front display panel to look at the problem
  • singh_chhatw Jun 02, 2010
    The problem is with ice chute (mechanical) and nothing to do with defrost timer. The black plastic flap stays closed even when you push the lever to dispense ice. The ice gets piled up on the flap and fills the chute. All I want to know is how to open the front black panel to see why the flap is stuck or if the solenoid stopped working.
  • 259 Answers
To access the dispenser area, you will first need to remove your display cover. This is the piece that has the buttons you press to make your selections. Place the tips of your fingernails along the bottom edge of the plastic cover (you will see looking up into the dispenser opening) and pull forward to release the display cover. After the display cover is released you will need to disconnect the two or three wire jacks from the back of the board (on back of display cover). With the display cover off you will now see the dispenser housing. There will be either three or four phillips head screws holding the housing to the dispenser opening. remove these screws and pull the housing froward. You may have to lower it a little to clear the water spout and be aware of the wires that connected to the board so as not to pull on them.
Be advised that the flap you are seeing is intended to be there and is supposed to open when the ice dispenser is pressed. If it is not opening you may either have a bad dispenser board (WR55X10195) or bad ice door solenoid (WR62X10055). Would not hurt to have these parts on hand when dissasembling this unit and return whichever one is not needed.
Good luck!!
Let me know if you have any more questions on this!!
Thanks,
Bob
Posted on Aug 09, 2010
  • 4,070 Answers
There is a solenoid that operates the door that could have stopped working. Can you hear it? The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong. Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Posted on Jun 02, 2010
  • 857 Answers
If the Evaporator fan is running this will not apply. Every so often your refrigerator automatically goes into Defrost mode. This is when the machine shuts down the motor, turns off the fans and kicks on a heater located inside the freezer. If the machine has entered defrost and the timer has malfunctioned this may be your issue. How to check this is going to depend on which type of timer you have. Most machines have a timer that looks like the one pictured here. They can be located anywhere from back behind the compressor to behind the controls where you set your temperature. To check this type of timer to see if it has entered defrost and got stuck is rather easy once you locate the timer on your machine. All you are going to need is a flat head screwdriver and all you need to do is advance the timer. To do this, turn the dial on the timer clockwise looking at it straight on. You will notice that as you spin the dial around it clicks. At a certain point you will hear a different distinct click. That is the timer going into defrost. If you turn the dial just a little bit further you will hear that distinct click again. That is the timer going out of defrost. Turn the dial to make sure it is just passed the second distinct click. At that point the freezer fan should be running. You will hear the fan shut off when the timer gets to the first "click" and come back on after the second one. If the timer is not in defrost and the relays are not getting voltage you need to do one more test to see which is the problem. From here you will need to locate the thermostat on your refrigerator.
Testing the Thermostat or "Cold Control"
Most older style refrigerators have a thermostat that controls the temperature of the refrigerator. The freezer has an air diverter that directs a portion of the air from the freezer to the fresh food section. Usually the only thing inside a refrigerator that detects temperature is the fresh food thermostat. The freezer stays frozen because of the amount of time the unit calls for cold inside the fresh food side. When it cools the fridge side, its also cooling the freezer. It basically will continue to freeze the freezer as long as the machine is not in temperature that is as cold as the fridge should be. Like your garage in the winter time.
To test this Cold Control you basically need to run a jumper wire between the two wires going to it. The contacts inside are either open or closed. If it needs to cool, they close. If it's happy with the temperature inside the fresh food side, it opens. You need to test it to make sure that it is not stuck "open". You can create a direct short between the two wires going to it. At this point, if the defrost timer is not in defrost mode and the compressor tested good, jumping the thermostat should start the compressor. If not, replace the defrost timer. If the compressor starts up, replace the fresh food cold control.
My refrigerator won't dispense ice cubes or crushed ice or water at the front door, I was wondering if it could be the Touch pad control panel on the front of the refrigerator. If it is can you give...
The front touch pad board /panel which you are referring is called dispenser board.To access the dispenser board assembly, click this link below:---
http://howtobyme.blogspot.com/2011/06/ge-side-by-side-refrigerator-will-not.html ------------ The dispenser board removal procedure is mentioned at the last on the link instructions.-------- -------------- But the engineer at your place has pointed you to right direction.The main control board is most probably the cause of problem.One more important thing.There are many other users too facing same problem with there ge side by side refrigerators.This problem occurs in many ge model refrigerators. There was service letter released by Ge for this problem.Click this link, to read the letter:--- http://howtobyme.blogspot.com/2011/07/ge-side-by-side-refrigerator-wont.html -----------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 28, 2011 | Refrigerators
Flap on inside of ice shute not opening to allow ice to come out
It may be more serious, but first check for ice around the sides of the ice delivery chute. Indeed it could be the solenoid.
Sep 21, 2017 | Whirlpool GS5SHAXN Side by Side...
Flap does not close by itself, ice builds up on chute; when you put glass to fill, nothing comes out or an avalanche. Ice builds up in chute, flap won't close even manually. Ice maker stops producing.
I have had the same problem. The issue is with the solenoid that opens the flap. For a temporary fix you can just squirt some oil on it. Remove the control panel (pull it towards you from the bottom). Disconnect the three connectors. Then unscrew the four screws in the panel behind the cover. You will see the solenoid on the top right. Just squirt some oil on it and it should get it working again for a while. For a long term fix order a new solenoid, they are about $25.
Jan 22, 2010 | GE GSS25JFM Side by Side Refrigerator
Frost inside the ice dispenser chute and the ice cube dispenser seems "stuck" on crush mode instead of dispensing full cubes.
The stuck on crush mode , is caused by ice frosted in front of the ice bin , blocking the ice bin flap from opening , when calling for cube ice . Removing the ice bin and cleaning or defrosting completely , will solve this problem , AFTER , resolving the frost in shoot problem .
Remove the top freezer door hinge cover , and disconnect the plug there . This removes any power , going to the door . If no plug there , remove the bottom kick plate , by removing the screw on each side in the front , and disconnect the receptical from the wires comming from the bottom of the freezer door .
Remove the dispensor control board , by prying , or pulling , from the bottom of the board . Disconnect the 3 plugs to the board . You should now see the white dispensor cover , being held on by 4 screws . Remove these screws , and slide the cover out .
In the top right , inside the dispensor area , you will see a solenoid with a plunger , with the door flap arc , inserted into the plunger . Usually rust inhibits the movement of the plunger , keeping the door flap from closing completely .
Remove the 3 screws holding the plunger and solenoid ( part number WR62X10055 ) and replace . Cleaning will not help , due to rust will return .
Oct 10, 2009 | GE Refrigerators
Ice dispensor flap is little warped.
the number for ge parts service is 1-877-959-8688. make sure you have the model # and serial number. if you don't have a manuel or if you have one that covers more than one model in it than you have to look for a little black most likely silver plate wich will have that info on it. if it's not on the inside or front of fridge anywhere you will have to pull it out from the wall because it will be on the back of it. hope i helped you.
Aug 15, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Gss25jfmc side by side
Either the defrost heater (in the coil) dont work or the deefrost termostat(round thing with two wires atached to the coil) or the timer (black thing with a plug with 4 o 5 wires),it could be at the botoom front of the refrigerator,pulling the grill,or inside the fridge in thecold control box.
Mar 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Ice dispenser door flap does not stay shut
IS IT A GE? GE HAVE A PROBLEM WITH DOOR SOLENOID IN CUP CHUTE RUSTING,GET A FLASHLIGHT AND LOOK UP THERE,IF IT IS RUSTED YOU WILL HAVE TO REMOVE FRONT PANEL AND REPLACE IT,THANKS-MIKE
May 30, 2008 | Refrigerators
GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Oct 02, 2007 | GE 17.2 cu. ft. Top Freezer Refrigerator...
GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS Logo
67 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
