Question about Yamaha Audio Players & Recorders
Yamaha tsx 130 switches off when dab or fm selected
2 Suggested Answers
Am here
  • 36 Answers
SOURCE: I have a Yamaha TSX-130. Won't play CD when alarm set.
hi go to the alarm option in your system and diable the repeat option and enable play all it will work thank u
Posted on Aug 24, 2009
How do I set the fm volume to be the same as dab?
This depends on the Music System. Check the manual, check in settings and see if there is volume normalizer or try keeping the eualizer in defult, or reset the system.
Oct 04, 2014 | Car Audio & Video
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
How do I set the alarm clock on my wharfedale ne 3120?
Press the INFO button several times until you see "Alarm Status" displayed. I had to press it five times.
Then use SELECT button to choose between ALARM OFF and ALARM ON. If you choose ALARM ON, you can adjust the alarm time by first holding down the SELECT button until the display flashes. The you use the UP and DOWN buttons on either side of SELECT, to adjust the time, the type of alarm (Beep, FM or DAB) and if you choose FM or DAB, you then select the preset. Exit by pressing SELECT a final time.Then the INFO button to exit from setup.
Hope this helps.
Feb 10, 2011 | Vacuums
Yamaha tsx 120. When ipod is fully charged when playing music,the yamaha unit goes into pause mode and music stops! I've checked its not in sleep mode too!
See one of my other posts re a TSX130 issue that turned out to be some corruption of the iphone. when the OS was changed it cured it.
Try another ipod first to prove/disprove this
When my iphone 3gs was fully charged it used to turn the TSX on playing...OS upgrade cured this too
May be the same issue you have?
AW
Aug 15, 2010 | Yamaha TSX-120BL Desktop Audio System ...
Technika fm/digital frozen
Possible shorted power supply capacitor or bad diode.
Rod
Apr 20, 2010 | Audio Players & Recorders
I have lost the operating manual for a technika DAB 109 Radio
I HAS SAME PROBLEM BUT FOUND THE ANSWER. PRESS STANDBY AND TURN UNIT ON, THEN PRESS ALARM BUTTON, DISPLAY SHOWS ALARM 1, PRESS SELECT BUTTON DISPLAY SHOWS FM/DAB/BUZZ, PRESS LEFT/RIGHT BUTTONS TO SWITCH BETWEEN WAKE UP OPTIONS, THEN PRESS SELECT AGAIN, DISPLAY SHOWS OFF, PRESS LEFT/RIGHT BUTTON TO TOGGLE BETWEEN ON/OFF LEAVE 'ON' SHOWING, PRESS SELECT AGAIN DISPLAY WILL SHOW ALARM TIME, USE LEFT/RIGHT TO SET HOUR THEN PRERSS SELECT, USE LEFT/RIGHT TO SET MINUTES TEHM PRESS SELECT AGAIN, DISPLAY WILL NOW SHOW SMALL ALARM CLOCK IN DISPLAY WINDOW, THIS MEANS ALARM IS NOW SET.
Mar 07, 2010 | Audio Players & Recorders
Aug 24, 2009 | Yamaha TSX-130BL Desktop Audio System ...
Need manual for Alba Clock Radio CRDAB301
Sorry m_gerard, I can't help you with the manual.
However here is a partial list of operations for the Abla CRDAB301:
Switch on
  • Press STANDBY
Switch off
  • Press STANDBY
Factory Reset:
  • Switch the radio on;
  • Press and hold MENU for 2 seconds
  • Press SELECT.
Switch between FM and DAB:
  • (radio must be on)
  • Press DAB/FM
Tune & store all DAB stations:
  • Press MENU
  • Press ">" three times (or until display says "Autoscan full")
  • Press SELECT
To listen to another DAB station:
  • Press "<" or ">" until the station name is displayed
  • Press SELECT
Hope that helps!
Apr 20, 2009 | Audio Players & Recorders
Deleting memory on Mikomi DRF350x Dab radio
To perform a system reset on a Mikomi DRF350X:
1) Turn on
2) Switch to FM using the 'DAB/FM' button
3) Disconnect power (e.g. unplug the PSU from the mains)
4) Push and hold 'Enter' whilst reconnecting the power
Mar 12, 2009 | Electronics - Others
How do i reset a HITACHI AX-M131U DAB/FM/CD/USB/MP3 MICRO HI-FI SYSTEM i want to retune it
push the funtion button till dab bomes up on the screen then push in the info button and it will start to retune dab. for a total reset just push the select button 1 second after you hold the info button for 5 seconds
Mar 09, 2008 | Audio Players & Recorders
26 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
