Question about LG 32LG30 32 in. LCD HDTV
Tv is on but we have no sound.
Menu show speakers are on and volume is turned up but still no sound.
  • 88 Answers
If you are using cable box with HDMI hookup, go to the settings and be sure the HDMI audio is turned on for the cable box as well. A firhter test would be to hook a dvd player.......if that has no sound.......you will neeed the main board replaced,but more than likely it is the settings
Posted on Jun 02, 2010
My new Vizion tv has a vizion sound bar, the sound comes out with an echo, how do I correct?
Your TV speakers should be turned all the way down or off when you use a separate sound system such as a soundbar. Using them with the soundbar may cause echoes and the TV speakers do nothing to improve the sound.
Look at your TV's audio menu. If you can, turn the TV speakers off completely at the menu. Also see if you can set the analog audio output to "variable." This will allow you to control the soundbar's volume with the TV remote.
Jul 08, 2017 | Echo Computers & Internet
Muted my sharp le 810 and now i can't retrieve the sound
If you push the volume button on set does it show on screen?
My guess would be the sound may be turned down on the box or tv or maybe in the TV menu the speakers may be turned off.
Does not sound (pardon the pun) like a circuit repair but like an error.
Check all audio settings or options first in the set and then the box.
Mar 21, 2012 | Sharp Televison & Video
No audio,tried menu items and selections,nothing.The sound just went out,what do you think it might be?
There is no sound or low volume coming from the television speakers.
Solution Follow this procedure to troubleshoot when there is no sound or low volume coming from the television.
NOTE: Because each of these steps represents a possible solution to this issue, check the television status after completing each step.
Increase the volume of the television. Ensure the television audio has not been muted. Ensure no headphones are not connected to the television. If using a set-top box with a volume control, increase the volume of the set-top box.
NOTE: If the set-top box is connected using an Audio/Video (A/V) connection, ensure that the A/V cables are connected securely to the appropriate video input on the television.
Verify that the MTS settings of the television are set to MAIN or STEREO .
NOTE: If the source device is not set to stereo or is not capable of transmitting a stereo signal, sound may come from one speaker on the TV only, and the volume will sound low. In this case, adjust or replace the source device.
If the TV has a Simulated effect in the audio menu, turn it off . Ensure the televisions speakers are not set as the center speaker.
NOTE: Some televisions allow the televisions speakers to act as the center channel speaker when using a multi-channel receiver.
Verify that the speakers are set to ON in the television menu.
IMPORTANT: If the television has audio output jacks and they are connected to a stereo system, then the speakers on the television may be turned off. Some televisions require the internal speakers or the center speaker setting to be off before audio can be sent out to a stereo receiver via the audio out jacks.
Ensure all audio and video cable connections are properly connected to the television.
Test the television using another source like a VCR, DVD player or Blu-ray Disc™ (BD) player.
Reset the television to the original factory settings. To reset your TV to factory settings, turn the TV ON. Then, while pressing the UP ARROW button on the Remote Control, press the POWER button on the TV. The TV will turn itself OFF then back ON.
NOTE: If your remote control does not have a RESET button or the procedure did not reset the TV to the factory default settings, perform a power reset.
If the issue is still unresolved after completing all the troubleshooting steps suggested, service may be required.
Jan 30, 2011 | Sony FD Trinitron WEGA KV-36FV27 36" TV
"TV Volume is fixed" shows up on Sony model #
Go to Audio Menu and turn On tv speakers option. "TV Volume is fixed" message will disappear.
Click Sony Support link to download user manual copy of this tv and check page-63 fro more details.
Thanks.
Dec 29, 2010 | Sony Televison & Video
I have a Quasar TV that has worked perfectly fine until the other day. Picture is fine, but no sound. The speaker volume is on.
Check all your channels. If you are getting sound on some channels but not others it is a good possibility that your SAP setting is turned on. Simply go into your audio menu and disable the SAP. Not sure about your model tv but some Tv sets had a switch on the back to disable the speakers and some have a setting in the menu to disable the speakers. If you have a digital cable box hooked to the tv it is possible the cable box volume is turned all the way down which will override your tv volume. Check these options and hopefully one of them works for you.
Jul 10, 2010 | Quasar SP-3235 32" TV
Connect Bose System to Panansonic TV
in the tv setup menu there should be an item that will allow you to change the volume from variable to fixed on the output of the tv
Dec 07, 2009 | Panasonic Audio Players & Recorders
Sharp tv no sound turn up screen has fao is on what is that
The FAO that is showing up when you try to adjust the volume because the volume has been turned off to make the TV work with an audio receiver.  The sound was set up on the television to be off so that the sound came out of the audio receiver only.  I don't know your exact model's instructions, but I know on my Sharp instruction if you go to the Menu and then go to Audio Select and make sure FAO is off and Speaker is on.  This should allow you to adjust your televisions volume level.
Dec 18, 2008 | Sharp 25N-M100 25" TV
Volume on tv stopped working
HIT MENU, GO TO AUDIO (SPEAKER PIC) SCROLL DOWN TO "2ND PAGE" AND SELECT SPEAKERS ON. AND YOU MAY NEED TO ALSO SELECT SBS ON
Jul 16, 2008 | Toshiba 36AF42 36" TV
Volume wont work
In the menu for initial setup look for a setting for center channel and turn it off. If it is on you will have no sound because it turns the TV speaker into the center speaker for a surrond sound receiver input.
Jun 27, 2008 | JVC AV-48P775 48" HDTV
Surround sound not working through ordinary tv
Try connecting the red and white audio cords to your system from your cable box/satellite receiver instead of your tv. Worked for me.
Oct 01, 2007 | Audio Players & Recorders
LG 32LG30 32 in. LCD HDTV Logo
85 people viewed this question
Computer Repairing
Computer Repairing
