Question about XO Vision GX2146 Car Monitor
The monitor sais "cannot use this fuction while driving" is there a way to bypass this feature?
  • rjmar Jun 03, 2010
    excellent!!! it worked you are very knowledgeable and understanding this was well worth it thank you for your help
  • 503 Answers
You should have had a wire that you were supposed to run to your parking brake right? Well what this does is when the parking brake is disengaged it sends the signal that the car is driving. The easiest way to fix this is to simply ground this wire to the same ground you grounded your black wire to. It's that simple. Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Jun 02, 2010
I changed the battery in my 1998 F150 it was running fine now it doesn't run good it acts like it doesn't want to shift and it bogs down there's no codes in the light's not on?
You can try a drive cycle, see if it helps? There may be an idle relearn, if just idle issue? Usually it will relearn idle on its own by driving.
Drive Cycle Recommendations:
  1. Most OBDII monitors will complete more readily using a "steady foot" driving style during cruise or acceleration modes. Operating the throttle in a "smooth" fashion will minimize the time required for monitor completion.
  2. Fuel tank level should be between 1/2 and 3/4 fill with 3/4 fill being the most desirable.
  3. The Evaporative Monitor can only operate during the first 30 minutes of engine operation. When executing the procedure for this monitor, stay in part throttle mode and drive in a smooth fashion to minimize "fuel slosh".
WARNING
STRICT OBSERVANCE OF POSTED SPEED LIMITS AND ATTENTION TO DRIVING CONDITIONS ARE MANDATORY WHEN PROCEEDING THROUGH THE FOLLOWING DRIVE CYCLES.
For best results, follow each of the following steps as accurately as possible:
OBDII Monitor
Exercised
Drive Cycle Procedure
Purpose of
Drive Cycle
Preparation 1. Install scan tool. Turn key on with the engine off. Cycle key off, then on. Select appropriate Vehicle & Engine qualifier. Clear all DTC's/ Perform a PCM Reset. Bypasses engine soak timer. Resets OBDII Monitor status. 2. Begin to monitor the following PIDs: ECT, EVAPDC, FLI (if available) and TP MODE.
Start vehicle WITHOUT returning to Key Off. 3. Idle vehicle for 15 seconds. Drive at 64 Km/h (40 MPH) until ECT is at least 76.7°C (170° F). Prep for Monitor Entry 4. Is IAT within 4.4 to 37.8°C (40 to 100° F)? If Not, complete the following steps but, note that step 14 will be required to "bypass " the Evap monitor and clear the P1000. Engine warm-up and provide IAT input to the PCM. HEGO 5. Cruise at 64 Km/h (40 MPH) for up to 4 minutes. Executes the HEGO monitor. EVAP 6. Cruise at 72 to 104 Km/h (45 to 65 MPH) for 10 minutes (avoid sharp turns and hills) Note, to initiate the monitor: TP MODE should =PT, EVAPDC must be >75%, and FLI must be between 15 and 85% Executes the EVAP Monitor (If IAT is within 4.4 to 37.8° (40 to 100°F)) Catalyst 7. Drive in stop and go traffic conditions. Include five different constant cruise speeds, ranging from 40 to 72 Km/h (25 to 45 MPH) over a 10 minute period. Executes the Catalyst Monitor. EGR 8. From a stop, accelerate to 72 Km/h (45 MPH) at 1/2 to 3/4 throttle. Repeat 3 times. Executes the EGR Monitor. SEC AIR/CCM (Engine) 9. Bring the vehicle to a stop. Idle with transmission in drive (neutral for M/T) for 2 minutes. Executes the ISC portion of the CCM. CCM (Trans) 10. For M/T, accelerate from 0 to 80 Km/h (o to 50 MPH), continue to step 11. For A/T, from a stop and in overdrive, moderately accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop vehicle and repeat without overdrive to 64 Km/h (40 MPH) cruising for at least 30 seconds. While at 64 Km/h (40 MPH) , activate overdrive and accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop for at least 20 seconds and repeat step 10 five times. Executes the transmission portion of the CCM. Misfire & Fuel Monitors 11. From a stop, accelerate to 104 Km/h (65 MPH). Decelerate at closed throttle until 64 Km/h (40 MPH) (no brakes). Repeat this 3 times. Allows learning for the misfire monitor. Readiness Check 12. Access the ON-Board System Readiness (OBDII monitor status) function on the scan tool. Determine whether all non-continuous monitors have completed. If not, go to step 13. Determines if any monitor has not completed. Pending Code Check and Evap Monitor "Bypass" Check 13. With the scan tool, check for pending codes. Conduct normal repair procedures for any pending code concern. Otherwise, rerun any incomplete monitor.
Note: if the EVAP monitor is not complete AND IAT was out of the 4.4 to 37.8° C (40 to 100° F) temperature range in step #4, or the altitude is over 2438 m. (8000 ft.), the Evap "bypass" procedure must be followed.Proceed to step 14. Determines if a pending code is preventing the clearing of P1000. Evap Monitor "Bypass" 14. Park vehicle for a minimum of 8 hours. Repeat steps 2 through 12. DO NOT REPEAT STEP 1. Allow the "bypass" counter to increment to two.
© Ford Motor Company
Jun 18, 2017 | Ford F-150 Cars & Trucks
3680 hard drive failed, then replaced, installed Win XP Pro. Sceen non-fuctional, but will operate with external monitor. Do I need drivers or is the screen dead? Thanks, Terry M.
Hi Terry,
Basically you dont need any drivers for the monitor to make it work, as you noticed even if you dont install a driver the monitor will still open for ypu to use it, the problem your facing right now is that the lcd of your laptop might be faulty. the good thing was you can still able to use an external monitor. Just back up the files and bring the computer to a depot so that they can replace the LCD
Thanks for usng Fixya
Jan 24, 2011 | Acer Aspire 3680 Laptop
How can i bypass the e-security feature on this monitor? i built a new tower and when i switched monitors. the monitor prompted me for a password...
install monitor on the last tower it worked on and then remove password or disable security feature. then move to new tower
Dec 15, 2010 | Gateway FPD2275W LCD Monitor
Why does my screen goes to sleep everytime I start my computer
Go into power options and turn off the fuctions for when the hard drive turnes off and when the monitor turns off, that should keep the computer from going to sleep.
Apr 21, 2010 | Dell Dimension 4600 PC Desktop
I installed a tview in my truck today it works ok but when i turn my headlights on it goes to rearview and i cant listen to music
This is a feature to stop it being used while driving.. You need to find and bypass, you really shouldn't, the "Drive inhibit" wire.circuit. They are all different, either that or rewire to an always on positive. No through "Key"
Mar 10, 2010 | Car Audio & Video
Need help to setup the scan fuction for Canon Image runner 4570
Do you have the send feature or just scan? If just scan you need to install scan gear to the computer you want to scan to and configure scanner, than can pull scan fro canon to any viewer installed on your computer. If you have the send feature, make a folder on the c drive of the computer , share the folder with all permissions. Touch send on screen, reg. new address, touch file, arrow down to smb file, browser button to see your network, highlight your network, touch down highlight your computer name, enter user name and password as shown, log in to your computer from canon and highlight the shared folder and hit ok. you should now be able to send to that shared folder
Oct 24, 2009 | Canon Office Equipment & Supplies
Graph
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Sep 09, 2009 | Texas Instruments TI-84 Plus Calculator
Bypass parking break feature on the Jensen VM9311TS
You can purchase an aftermarket bypass kit from electronics store or off ebay... But hey, be careful, no watching movies while driving... K
Jun 05, 2009 | Jensen's VM9312 Car DVD Player
Dimenssion error when trying to graph a function
Dec 14, 2008 | Texas Instruments TI-83 Plus Calculator
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
XO Vision GX2146 Car Monitor Logo
35 people viewed this question
Top XO Vision Car Audio & Video Experts
mega_mind
Andy
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
