Question about LG WM1812C Front Load Washer
Re: No Power
Hi there, this morning, while washing is in progress, our 2 year old todd sneaked into the laundry room and pressed a couple of buttons. After that, there seems to be no power to our washing machine.We tired checking the connections, turn off and on the mains power but still there is no response. Help!
  • 489 Answers
It sounds like the control board has an issue and needs to be addressed by a qualified LG technician.
Posted on Apr 28, 2008
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
I was using my dvd players component outs for a year but my hi def tv died so when I hooked up my old tv to the single video out I can't get any picture out of it. I think I need to get into dvd player set...
If its an old Sony dvd player then check Progressive Scan button at rear or some may have it on front to turn off to get composite video output (yellow video out)
And if it does not have any manual switch for progressive scan then turn off dvd player by pressing power button on its remote control, press 3, 6, 9 on dvd remote and press power to turn dvd player On.
That will turn off / disable progressive scan mode and you will get video output from yellow video out jack.
Jul 31, 2010 | Sony Televison & Video
Burning smell at end of wash
could be the belts but it could also be the motor depending on the smell
Jun 04, 2009 | Kenmore 22622 Top Load Washer
Can't move machine without shipping bolts?
if your just moving downstairs youll be fine just be careful
Apr 16, 2009 | Washing Machines
Beeps 3 times when Power button is pressed
hi im josh in cebu phils. the problem is your washer is on a short circuit. try to check the wires if it has no cut.or loosen. good luck.
Dec 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washing machine ghw9100lw1
To turn off "Control lock" : press and hold the "End of cycle signal" button for three seconds.
Nov 17, 2007 | Washing Machines
Dell 17inch LCD Display - Blank
Hi, My name is Todd and I'm a customer advocate at Dell's corporate headquarters. My team helps customers via blogs, forums, and other tech sites online. You said the monitor is 2 years old. Do you have the original order number still? Depending on how you purchased the monitor it may have up to a 3 year manufacturer warranty and I may be able to replace it if it is within that warranty period. Please email me at Customer_Advocate@Dell.com if you can locate the order number and I'll be glad to see if its still under the manufacturer warranty. Include my first name (Todd) in the subject line of the email so it can quickly be routed through to me, and include the order or customer number if you have it. Thank you, Todd Customer Advocate Dell, Inc. http://direct2dell.com/one2one/archive/2006/11/19/3648.aspx
Apr 25, 2007 | Dell E173FP 17" LCD Monitor
LG WM1812C Front Load Washer Logo
122 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
