Question about HP PSC 2355 All-In-One InkJet Printer
Printer will not print color even though I installed a new color ink cartridge. Help!
    Scholar:
  • 53 Answers
Make sure that the Cartridges are properly installed. And the copper contacts on the printer and on the Ink Cartridge are clean.
Try replacing them. Make sure that the cartridges are not Refilled, Remanufactured and Expired.
Check for expiration date mentioned on the back of the printer.
If you still face the issue, replace the cartridges, if the issue resolves. Contact HP to replace the faulty cartridges. If not, then the issue is with the Printer's hardware.
Posted on Jun 02, 2010
  • 5 Answers
SOURCE: printer won't print color
when you change the ink cartridges you are NOT changing the print head. The print head is in the carrier. If the print head has become clogged or worn then usually it needs to be replaced. Unfortunately it us probably cheaper to buy a new printer.
Posted on May 06, 2007
nassimjd
  • 104 Answers
SOURCE: I just installed a Lexmark
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Posted on Mar 30, 2009
  • 81 Answers
SOURCE: My printer prints in the wrong color!
Check to see if the correct colour is in the correct place in the printer. You may have the Cyan and Magenta mixed up
Posted on Aug 22, 2009
  • 39 Answers
SOURCE: My Canon MP145 is not printing Magenta color.
USE ONLY ON PLAIN PAPER , STANDARD QUALITY.
Posted on Jul 25, 2010
jay767
  • 386 Answers
SOURCE: I installed a new Ink
Hi Good day!! well i know that you can fix it. 1st off all is there any message error in your printer? if none then we will try to troubleshoot it in the printer spooler. Printer spooler is located in the services. please try the following.
1. turn off in a few seconds and then turn it on see if the ink cartridge is moving.
2. Click "Start
3. Click "Setting
4. Click "Control Panel"
5 Click "Administrative tools
6. Click "Services you should be on the services box now.
7. in the service box find "Printer Spooler
8. Click "Printer Spooler" all you need to do is to restart the printer spooler Stop and then START it again.
Try to print now hope your ink cartridge move..
ReGARDs
JR
Posted on Oct 07, 2010
How do I make a test page for my printer to check color.
You need to clarify :
1. Your printer cannot print color even though it prints color well from a test page;
2. Your printer cannot print color in a test print page.
If it is the first one, then you have to set it properly in Window Print Configuration page of that printer;
If it is the second one, then you have to check whether you have installed the color ink cartridge properly in the printer. If the color ink cartridge is installed properly, try to replace another new color ink cartridge. Finally it is still not work, then you have to bring back to the repair center.
Jan 19, 2013 | Dell V715w All-in-One Wireless InkJet...
Failure of Printer to Print Color
Try using a new HP ink cartridge. I had the same problem with a printer I purchased off of CraigsList even though the ink level was good. I installed a new color HP ink cartridge and it printed without a problem.
Jul 29, 2010 | HP Photosmart C3180 All-In-One InkJet...
New Cartridges - not all color ink printing!
It sounds that the ink inside the cartridge has partly dried up.
This can happen to my printer when I don't use it for a couple of months too.
Hope this helps!
Feb 04, 2010 | HP PhotoSmart C4180 All-in-One Color...
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
something like this
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Maybe you can try to rest the black ink level 1st. To reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
Jan 14, 2009 | Lexmark X2500 All-In-One Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Color ink low
Try this link to help reset all canon PG and CL cartridges.
http://swapink.com/Merchant5/merchant.mvc?Screen=caninst
By the way this sites prices are cheap and the cartridges are as good as new.
Scott
Jun 16, 2008 | Canon PIXMA MX310 All-In-One Printer
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
Use of black ink
My husband answered this for me- it takes different colors to make black, therefore it uses some of the color ink
Jan 16, 2007 | Canon Pixma iP6600D InkJet Photo Printer
HP PSC 2355 All-In-One InkJet Printer Logo
114 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
