Question about Hotpoint Aquarius WMA42 Front Load Washer
Burning smell Mid cycle there is a burning rubber smell coming from the dishwasher.
Hotpoint DWF31 dishwasher went bang mid cycle and mild smell of burning plastic. Still powers on, lights on correct setting but stuck at 77 mins with nothing happening. Water still inside. Any ideas
Sounds like you have burnt something. May have shorted out. Shut it down and pull the plug or could maybe cause a fire. Get a professional to look at it.
Dec 19, 2016 | Hotpoint Dishwashers
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
Bosch dishwasher smells burning rubber
Certainly could be a pinched wire in the door panel. I would remove the panel and see if anything is pinched or being interfered with like the rinse dispenser solenoid.
Dave
Jul 04, 2017 | Bosch Dishwashers
The dishwasher delays mid cycle and will stay in the same spot, just after "short wash." If allowed to just hang there, it also develops a slight rubber burning smell. If I turn the dial past...
it sounds like the timer has a worn gear and will need to be replaced if you check with your local parts distributor they are rebuildable for a lesser cost
Feb 28, 2011 | Dishwashers
My dishwasher doesnt seem to turn on to a cleaning cycle. barely any water is in there and it smells like it is burning sometimes. my water is on to the dishwasher. also water comes out of the valve in the...
Check your disposal. If newly installed the knock out plug was not removed. The smell could be food decaying. No water should be coming out of the vent on the sink.
Remove the rubber pipe from the dishwasher to the disposal.
Stick a screwdriver into the hole and look down the disposal from the top and see if you are able to see the screwdriver.
If not get a hammer and pop the plug out and reach in the disposal with your hand and retrieve the plug after you have unplugged the electrical cord.
Once the plug is out re-install the rubber pipe and secure it plug in your electrical cord and try your dishwasher again. Good Luck
Jan 07, 2011 | Frigidaire 24 in. FDB1050RE Built-in...
Cycle runs but dishes are still dirty. No water.
Sounds like an inlet valve. If there is no water in the pump when it runs you can burn up the rubber seals. After fixing the fill problem you should check underneath for any leaks.
Jul 03, 2010 | KitchenAid 24 in. KUDP01DL Built-in...
Maytag washer sounds like a jackhammer when rinsing - this is a new thing with all loads. Yesterday it shut down mid cycle while still full of water and we smelled a burning rubber smell. Any ideas?
There is only one belt on the machine (the burning rubber smell, probably). Sounds like something is wrong with the clutch /drive mechanism. Unless your an accomplished DIY'er, it sounds like a job for the Maytag Man.
Sorry.........................
Sep 15, 2009 | Maytag PAV2300 Top Load Washer
Dishwasher burning smell now not working
it sounds like the motor may have burnt out
Jan 13, 2009 | Dishwashers
"rubber burning" smell
check to see if the motor is overheating, the motor could
be getting hot causing the smell, if the motor is'nt overheating, then call the local repair man, we live in miami(florida), and we have a dish washer that keeps on rumbling, we are getting it fixed today, the only big big problem is it seems to draw alot of electricity when in operation, so there's my problem
p.s. is your dishwasher also rumbling and drawing electricity?
shawn henks
miami,fl
Nov 26, 2007 | Asko D1716 Built-in Dishwasher
Hotpoint DC28 Dishwasher Problem
u will more than likely find its the element... and i would not charge that for to come out.. ive one here im doing.. u can get the part for 40 quid on the net.. im charging to fix this one 90 in total.
let me know what happenes
Oct 15, 2007 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Hotpoint Aquarius WMA42 Front Load Washer Logo
77 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
