Question about HP LaserJet 5550dtn Printer
My hp color laserjet 5550dn doesn't recognize trays 3
CompuGuy44
  • 432 Answers
SOURCE: HP COLOR LASREJET 3500 41.3 ERROR
Check your settings under the properties menu. and in the software your using.
Posted on Jun 26, 2007
ThePhantom
  • 6 Answers
SOURCE: Tray 3 open or Empty
While tray 3 is detachable, when I remove it from my 2430dtn the printer won't display tray 3 options in any menus, so it looks like your printer recognizes that it is there.
The micro-switches that detect "open drawer" or "no paper" in tray 3 may be malfunctioning or the electrical connector built into the top of tray 3 may need cleaning.
(or, tray 3 may be out of paper <wink>)
Posted on Dec 11, 2007
  • 83 Answers
SOURCE: hp laserjet 8150. i have a problem, tray 3 empty,
CAUSE: This error message indicates the paper present sensor flag in one of the trays does not detect paper in the tray. This could be caused by one of the following:
  • A broken sensor flag
  • The tray paper guides being set too close and restricting the paper from being pulled
  • The tray is not lifting
SOLUTION: Follow the steps below to determine the cause of a false TRAY X EMPTY message. Tray 2 empty
  1. Verify there is paper in the tray.
  2. Open the duplex unit access door just above Tray 2 on the front of the printer.
  3. Check the black-paper present flag by looking in through the duplex access door.
  4. Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
  1. Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
  2. Remove the tray guides from the tray and reseat them. Ensure the guides are seated correctly and are in the correct slot for the size paper in the tray. Add paper to the tray and try printing again.
  3. Try another known good tray, if available.
The tray does not lift and the error is still present
  1. Remove the tray, remove the paper in the tray, and inspect the lifting plate in the tray for damage. Ensure it will lift freely by hand.
  2. Try another known good tray if available.
Tray 3 empty
  2. Remove Tray 2.
  3. Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
  3. Try another known good tray if available.
Tray 4 empty
  2. Open Tray 4 and check for an extra **** of paper stored on the left side of the tray. This can cause the tray to stall while lifting and result in a tray empty message.
  3. Defeat the interlock in the vertical transfer unit (VTU). Open and close Tray 4 and watch the tray lift through the VTU door on the lower-right side of the printer.
    NOTE: Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
  1. Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
  2. Inspect the paper present sensor for damage.
  3. Check for any broken plastic pieces in the tray that may be a broken sensor flag.
The tray does not lift and the error is still present Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
Posted on Nov 25, 2009
  • 240 Answers
SOURCE: default paper tray selection for HP LaserJet 4200tn
1) When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an “autoselect” process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
2) If paper is loaded in tray 1 and tray 1 is set "TRAY 1 TYPE=ANY" and "TRAY 1 SIZE=ANY" on the
Paper Handling menu, the printer will always pull paper from tray 1 first.
Posted on Dec 10, 2009
SOURCE: paper jam inside HP Color Laserjet CM1312 MFP, not
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Posted on Oct 12, 2010
Error 0XC0000005 in HP Color Laserjet 5550dn printer
uninstall and reinstall your printer drivers. Best to upgrade to HP Universal Print Driver version 6.3. Post Script.
Oct 14, 2016 | HP LaserJet 5550 Printer
Hp color laser jet 5550dn shows error code 10.10.02 supply memory error
This error codes indicates that one of the toner cartridges you have installed does not contain a valid chip on it. If you recently changed a cartridge that is the likely culprit.
Feb 28, 2015 | HP Color LaserJet 5550dn Q3715A Workgroup...
My printer hp color laserjet displays a printer error 57.07 i need to a process to clear the code
Try looking up that specific error code and it should tell you what you need to do.
Dec 28, 2014 | HP Color Laserjet 5550 5550n 5550dn...
Color Laserjet 5550dn code d'erreur 54.15
54.15 PRINTER ERROR Description There is a problem with the Yellow CPR sensor. Action
  1. Turn the printer off, and turn it on again.
  2. Clean the color registration detection sensor above the black print cartridge if the error does not clear.
  3. If this message persists, contact HP.
Jan 05, 2011 | HP LaserJet 4700 Printer
LaserJet 5550dtn Printer: blows mains fuse and power supply board fuse and b...
The fuse blows all time on High Voltage Poewr Supply, on HP Color Laserjet 5550dn,
May 16, 2010 | HP LaserJet 5550dtn Printer
No power on hp color laserjet 5550
here http://www.generalmanual.com/Printers/HP-Color-LaserJet-5550dn-Printer.htm
you can download this is printer user's guide (under "download now" near the bottom of the page) help you.
Sep 10, 2009 | HP Color LaserJet 5550hdn Printer
Yellow toner not being recognized with new toner installed
Probably dirty contacts on side of cart. Also if you take out drum and cart unit together, clean copper contacts with alcohol and cotton bud, also make sure in machine where they contact is clean
May 01, 2009 | HP Color LaserJet 5550dn Q3715A Workgroup...
Jam in top cover area
Replace your paper pickups and set your paper tray setting correct, both in the tray and the settings menu. That should help you out. The part# for paper-pickups is RF5-3739.
Mar 17, 2009 | HP LaserJet 4600dn Color Printer
To install a 500 sheet paper tray for hp laserjet 5 printer
just put your printer on top of your 500 sheet paper tray ( printer sit just on top of it )
then you have to go in your propertie menu ( on computer)
look for the accessory tab , and check for 500 sheet paper tray ( tray3 )
et voila !!
Dec 21, 2007 | HP Color LaserJet 4650DTN Printer
HP LaserJet 5550dtn Printer Logo
522 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
