Question about Brother Multi-Function Center MFC-665CW All-In-One InkJet Printer
Screen reads unable to print 50 error brother mfc-665cw
  • americani581 Jun 02, 2010
    my mfc-665cw printer displays a unable to print 50 and sometimes a unable to print 30 how can i fix this
    President:
  • 1,194 Answers
The main reason of this error is that some paper jam had lifted the long, thin, plastic encoder strip out of its slot inside the printer.
It is making the printer read a false paper jam which is resulting in the error "unable to print".
Removing this error may require a technician.
If your printer is under warranty period, then take it to a Brother repair center.
If you want to remove this error yourself try gently pushing the strip back into the slot when the printer is off.
You might have to use a screwdriver or other thin instrument to get to the strip.
Thanks for using Fixya.
Good Luck and have a nice day.
Posted on Jun 02, 2010
  • 503 Answers
The paper jam you had probably lifted the long, thin, plastic encoder strip out of its slot. It is making the printer think paper is still jammed. Try gently pushing the strip back into the slot. You might have to use a screwdriver or other thin instrument to get to the strip.
Be sure printer is off when you do this.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
Im getting unable to print 50 error on my brother mfc 665cw
Sep 18, 2011 | Brother MFC-665CW All-In-One InkJet...
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Brother MFC-665 CW with "unable to print 4F" error
My MFC 665CW popped this same "Unable To Print 4F" error recently making the machine fully useless. Just an annoying triple beep and repeat error message to screen when trying to do anything at all with it. I wrote Brother about it. They said to check all through the machine (with a light) for any paper torn off inside, or unwanted foreign objects. This is a good step to do anyway to help maintain the printer. If that is not it, they said it would be a mechanical malfunction. I tried "resetting" by unplugging it for a while as they suggested to no avail. Also while I did find a bit of paper torn off down in my MFC 665 removing it had no effect.
Jul 10, 2009 | Brother MFC 420CN All-In-One InkJet...
MFC-665CW "unable to print" 50 error
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment. You will need to turn off the printer and then push it back into slot to fix it. Let me know if you need more help. Sai.
Jun 11, 2009 | Brother MultiFunction Center MFC-440CN...
I have a brother mfc 665cw printer, had a printer jam, cleared the jam and now recieve unable to print 50 error, unable to copy or print. Have found some information about the encoder strip but I have no...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Brother Multi-Function Center MFC-665CW...
Cleared printer jam, message Unable to print 30
...and 50? Is it toggling between those two error codes?
Anyway, see here what to do:
http://www.fixya.com/support/t211210-brother_mfc845cw
Mar 11, 2008 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-665CW All-In-One InkJet Printer Logo
151 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
