Question about Samsung SyncMaster 2220WM 22" LCD Monitor
Monitor turns off by itself during normal usage.
From time to time, several times s day monitor turns off by itself.Then I turn it on and it works perfectly, untill it "decides" to turn off again, which is very annoying. What shall I do about this?
    Scholar:
  • 67 Answers
There are a few things you can try in order to narrow the the cause. First there's the easy outside-the-PC stuff such as:
- hook up a different power cable
- hook up a different video (VGA/DVI) cable
- You can always try switching to the other type of cable (try VGA if you're on DVI and vice-versa) to see if that makes a difference, assuming your monitor as both connectors.
- try connecting same monitor (and power/video cable) to a different PC for a day and see if it turns off there as well.
- For that matter connecting a "known good" monitor to your PC to see if that monitor also acts that way on your PC.
On the software side you can disable the power management features related to the display to see if that makes any difference.
If you were to connect this to a different PC with a different VGA/DVI cable and power cable and it still did it that I would say it's probably the monitor itself (unless the PCs were identical or something and under control of the same domain policies or some craziness like that).
At some point you probably want to call the manufacturer and see if an RMA is an option. I would recommend trying some things before that though. I hope this helped!
Posted on Jun 02, 2010
Monitor will not turn on.
Could of damaged some internal parts sorry
Nov 27, 2013 | Myron & Davis Ans185mg 8.5-inch Flip Down...
My monitor it turn on and off itself
Try connecting your monitor to a different computer.
If it still turns on and off, the monitor is failing.
It needs to be replaced.
Oct 09, 2013 | LG Computers & Internet
I have exactly same problem
Sound like your display is having issues with the inverter board. When the power supply detects a short circuit, it turn off by itself. When you try several times, you may be able to "bypass" the circuit protection but the damaged parts still having problems. This issue may be related with the DELL display issues.
The display needs to be fixed by someone with experience in electronics repair.
Sep 29, 2009 | Microsoft ChiMei CMV938D 19" Widescreen...
Monitor power light blinking on and off but no picture
try testing the monitor on another computer. if you dont have an extra desktop or laptop to test with. take over to a neighbor or a friend. if the monitor still doesn't turn on or no signal. the monitor is defective and needs to replaced or repaired by a technician
good luck
Feb 28, 2017 | Dell E173FP 17" LCD Monitor
View sonic flat screen monitor
Problem seemed to be a short in the power cable to the monitor. Replaced the power cable and for the time, the monitor is working correctly.
Jul 07, 2008 | ViewSonic VX924 19" LCD Monitor
LCD Monitor - green power light blinking - nothing on monitor
Carol,
It sounds like your computer is putting the monitor in power save or sleep mode, and the monitor doesn't respond appropriately. The monitor might be faulty, or overheating. Make sure there is adequate ventilation around the monitor, and that it is clean and free from dust around the vents on the case.
Another thing to try is to check your computer's screen saver and power saving settings. Try turning off the "turn off monitor after [interval]" setting and see if the monitor still shuts off after several hours.
Good luck, hope this helps.
Jun 10, 2008 | Gateway FPD2275W LCD Monitor
Black Screen on W1700 LCD TV
As i said early ther should be an problem with your power card or ram...please upgrade it...
Dec 31, 2007 | AOC LM729 17" LCD Monitor
Power Failure
If you mean the Monitor is powered by an external power supply Then that indeed is an option worth trying Simply get a multiple voltage one and set it to the voltage of the existing one. There may be internal problems such as the inverter But this will be a repair shop job.
May 22, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Samsung SyncMaster 2220WM 22" LCD Monitor Logo
186 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
