Question about Canon MultiPASS MP370 All-In-One InkJet Printer
Printing doesn't come through on the paper
When I send a job to the printer, the paper goes through as though it's printing, but the paper comes out completely blank. The same is true for copying.
Two possible factors:
1) I usually use Staples print cartridges and for the first time used the Canon version expressly for this printer
2) I installed the new cartridge, then went away for two months, so the printer hasn't been used for two months.
  • 3 more comments
  • LCLaw Apr 09, 2008
    I just put one new black and one new colour cartridge in the machine and the problem is still there -- the paper goes through as though it's printing but nothing is printed. Help!
  • ener1561 May 15, 2008
    Although I hv bought the printer for a couple of years but it is hardly use. I have the same problem but only with the black ink. I have changed toner twice (originals) but it doesn't help. If anyone has a solution please help. Can't afford to buy a new printer. Thanks
  • TD24 Sep 10, 2008
    Same problem. Does not print when copying black or printing black text from computer. Will copy in colour fine. Replaced printer head (£45) and run deep clean 5 times and to no avail. Still makes all movements and noises to print but nothing comes out on page. There is evidence of black ink on the print head so assume balck ink getting through printer head but not onto page.
    Any suggestions welcome.
  • bobharley Oct 02, 2008
    Printer carries out the print instruction, but no ink on the paper. I have also replaced the print head and tried canon and other new inks to no avail.
    Regards Bob
  • Martin Ryan Dec 29, 2008
    I am an engineer and looking for some info on this fault also.
    I have fitted a new print head and also the purge unit and neither have made any difference, apart from the fact I am now getting error ##345.
    I have not tried new carts as I have non available, and am thinking of ordering a new carriage unit and main board to try.
    Would be great full to here what you are thinking on this fault.
    Genius:
  • 2,785 Answers
Dear lclaw
it is very nice for the two information.
try using another cartridge form staples because as u said your cartridge might be dried out.
Plz post your findings
Posted on Apr 09, 2008
  • Rajkumar Bordoloi
    Rajkumar Bordoloi Apr 10, 2008
    is it Staples print cartridges or another.if yes then your printer needs servicing.
When i power on my printer, its blinking indicating there is paper jam and no paper are in the tray, its also blinking at the part. kindly advice on how to go about it
if a computer is trying to send a print job, a no paper situation will make the printer think the paper jammed when it tried to pick it up.
Put at least one piece of paper in the tray.
If a page comes out, determine what computer is generating it, and kill the print job at the computer.
Then turn the printer back on and see if the error is gone.
Easier test - disconnect everything but power from the printer. have at least 1 sheet of paper in the tray. Power it up. If everything is normal, you need to track down the machine on the network that's trying to send a print job.
Mar 15, 2011 | HP LaserJet P2015 Printer
My print job starts out printing correctly on the label but as it continues it gradually starts printing off the label. I then calibrate the machine and again once we send another printer job to the...
We had this same issue at one point. Ours turned out to be that the paper spool was not correctly centered. Open the hatch, you will see where the paper is clipped between the feed guides. Open the guides and make sure the paper is pushed all the way back up against the side with the control panel on it. Then clamp back down the guides, recalibrate, and see if that works!
Mar 09, 2011 | Zebra Z4M Printer
'check paper size' error has come up and nothing can now be printed. If turned off and on the last print which had caused the error prints out then the error message appears again. How can i clear this
This is usually caused by data within the print job. Microsoft Office sends paper size and job data with each job. Clear all print jobs in the computer sending the job.(Start/Printers/double click the canon printer and delete all jobs in the print que. Clear the Canon by off/on. Open a program and print a standard letter size document to test. This can be corrected by going to the page/document setup choices under "File" or the Ball in MS Office. Usually this is set to A4 or Bypass by mistake within the application.
Thanks
Jan 06, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
I would like your advice as to how to stop a Printing job before completion on Canon LBP2900B I have been wasting A4 paper because the full job has to run its course even though I wish the job to...
when printing, you may press the CANCEL button on the printer, right-click the printer tray icon and click view print jobs, then cancel a print job before it completes. you may also want to try specifying only the pages you want to be printed instead of selecting all pages to avoid unnecessary print outs. hope this helps and let us know how it goes.
Dec 04, 2010 | Canon CFX-L4500 IF Laser Printer
Command sent to printer but printer is not printing the document
First of all make sure your network cable is connected properly and has not come loose.
Most likely though is that the IP address has changed .
Do you know your printers IP address? Have an old copy of the configuration to compare it to a new one?
That machine is notorious for changing the IP address and I really suspect that is the problem.
You can try turning it off and back on.
You can check the job status queue and be sure the machine is not holding a job . It could be " held for resources." What that means is a job was sent to the printer and the print driver and settings on the printer are different. I will not print if those settings are different.
By that I mean, on the print driver, it sends a job for 8 1/2 x 11 plain paper. The machine settings say it has 8 1/2 x 11 bond paper or visa versa. If the settings between your computer and printer are different it will hold the job until they match. Look on your printer screen and be sure the tray settings are correct.
Jan 07, 2010 | Xerox Phaser 8560DN Laser Printer
Hi,I am experiencing nothing printing on paper even though ink cartridges have been replaced and cleaning has been performed.ink absorber warning appears and says that absorbers are almost full and to push...
your print head is either clogged or damaged, A print head is the unit your ink cartriges sit in. If its a nedw or newer printer (under warranty) you can contact the manufacturer and they will send you a new print head at little to no cost-good luck
Dec 19, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
HP laserJet 2100 prints blank from manual tray
I bet you have a bad USB wire.Change the wire and I suggest reinstalling the drivers.
Oct 31, 2008 | HP LaserJet 2100 Printer
Paper goes through the printer as though printing but paper comes out blank
Just make sure the cartridges are not running out of ink. Try with different carts, It should work fine.
Apr 20, 2008 | Office Equipment & Supplies
Canon MultiPASS MP370 All-In-One InkJet Printer Logo
149 people viewed this question
old marine
old marine
