Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
Robinair 34700z displays toggle input, input 0
When powered on have to go through key sequence c1/r5, c2/r4, c3/r3, c4/r2, c5/r1 then display says toggle input, input 0. What do I do?
    President:
  • 180 Answers
You can try 1# With power on press and hold for 4/5 sec. up & down arrow key at the same time
2#With the power on press YES/START & NO/STOP key at the same time
Posted on Jun 06, 2010
Values of the resistors
Resistors R1, R2, R3, and R4 are arranged in a circuit as shown in the figure above. The direction of positive currents I1, I2, I3, and I4 through the resistors are shown. (i.e., negative current values correspond to currents in the opposite direction to that shown above). The values for the resistors and the batteries in the circuit are: R1 = 100 ?, R2 = 200 ?, R3 = 30 ?, R4 = 400 ?, V1 = 4 V, and V2 = 12 V.
Nov 06, 2016 | Televison & Video
Se bloqueo cuando enciende sale el mensaje press C1/R5 key
Press & hold for 3 to 5 second up and down arrow key at the same time to reset C1/R5
Hope this will help you. Best of luck!
Mar 23, 2011 | Robinair Cool Tech 34700Z Recovery,...
How do i unlock the region code
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767
or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Jan 02, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
Wiring diagram for oven motor 419720
Many modern gas stoves, ovens, furnaces, and other similar appliances use an electronic ignition rather than a continuously burning pilot flame to ignite the fuel. These are actually simple high voltage pulse generators.
  • Where starting is manual (there is a 'start' position on the control(s), a set of switch contacts on the control(s) provides power to the ignition module.
    • A problem of no spark with only one control indicates that the fault is with it or its wiring.
    • A problem with continuous sparking even with all the controls off or in their normal positions indicates a short - either due to a defective switch in one of the controls or contamination bypassing the switch contacts.
  • Where starting is automatic, an electronic sensor, thermocouple, or bimetal switch provides power to the ignition module as needed.
The Harper-Wyman Model 6520 Kool Lite(tm) module is typical of those found in Jenne-Aire and similar cook-tops. Input is 115 VAC, 4 mA, 50/60 Hz AC. C1 and D1 form a half wave doubler resulting in 60 Hz pulses with a peak of about 300 V and at point A and charges C2 to about 300 V through D2. R2, C3, and DL1 form a relaxation oscillator triggering SCR1 to dump the charge built up on C2 into T1 with a repetition rate of about 2 Hz. C1 A D1 T1 o H o----||----------------+-------|>|-------+-------+ +-----o HVP+ .1 uF D2 1N4007 | 1N4007 | | o ::( 250 V +----|>|----+ | +--+ ::( | | | )::( +---/\/\----+ | #20 )::( 1:35 | R1 1M | C2 _|_ )::( | R2 / 1 uF --- +--+ ::( | 18M \ DL1 400 V | __|__ ::( | / NE-2 | _\_/_ +-----o HVP- | | +--+ | / | | +----|oo|----+---------' | SCR1 | C3 | +--+ | | | S316A | .047 uF _|_ R3 / | | 400 V | 250 V --- 180 \ | | 1 A | | / | | R4 2.7K | | | | | N o---/\/\---+-----------+------------+----+-------+
Apr 23, 2010 | Vulcan Ovens
Problem with gopro hd
It means that your computer has limited resources to play up to R3 only. R4 HD is heavier to process that is why your computer freezes.
R4 and R5 needs higher processor speed, ram and the video card. Check and make sure that the 3 of them are compatible with each other and has outstanding bench mark.
For computer maximum performance use processor that has GPU.
Apr 07, 2010 | GoPro Digital Hero 3 Digital Camera
Lost instructions. How do you change value of tax
The c1, c2, & c3 are for exchange rates. To set the c2 exchange rate press AC. Press the MODE M/EX button till EXCH appears in the display. Press and hold the SET/% button for a few seconds until SET EXCH appears in the screen. Press c2, C2 SET EXCH RATE should be displayed. Enter the desired echange rate. For instance, today, Thai Baht is 32.8677. Once you enter your desired exchange rate, press the SET/% button.
To convert 100 dollars using the exchange rate you set on c2, make sure that EXCH is in the display by toggling the MODE M/EX button. Press AC, enter 100, press c1 then c2. Using 32.8677 as the exchange rate 100 dollars would be 3286.77 THB.
To convert 100 THB to dollars you would enter 100, then press c2 and then c1 yeilding 3.04 dollars.
You can also program a different exchange rate into the C3 button. To convert to that currency, you press c1 then c3. To convert from that currency, you press c3 then c1.
Hope that helps
Dec 23, 2009 | Casio MS-80TV Scientific Calculator
What is the Code for DVD-VR375?
2/Press menu button
6/Turn machine off
R1 - 29334
R2 - 38767 or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Mar 10, 2009 | Televison & Video
Making dvd player region free
2/Press menu button
3/Enter region code (See below for list) eg if your present region code is R1 enter 29334
6/Turn machine off
R1 - 29334
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Oct 16, 2008 | Televison & Video
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
232 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
