Question about Toshiba 32AV600E 32 in. TV
I have a Toshiba regza LCD 32AV600 TV set. The remote is not able to turn on the TV (only manually from the side of the screen). Other functions of the remote work fine. I tried using a different remote (from the cable company) and it's the same problem...
  • Toshiba Master
  • 8,457 Answers
Tries reset the tv back to factory setting and the cable box too by unplug,replug it back an hour later.Go to tv menu,go to PICTURE,go down to reset,so the Tuner board it reset it back to the factory setting.This should solved ur problems,not than the tv tuner board that recieve the bracasting signal board have probems.
Posted on Jun 02, 2010
  • 88 Answers
I would say it is the power function on the remote itself,but you say the cable one would not work it either. Put your cell phone in the picture take mode.........aim the toshiba remote at the camera.........you should see a flicker when press power.........this will ultimitely prove if the original remote is not working and possibly the cable one was not progrrammed for the tv. let me know how you make out
I REGZA 32 lcd tv, will not work for me function.when channel and press the button on the tv, it says panel lock.what problem?
read the owner manual, the book that came with the set--it is telling you the panel or front controls for the set (maybe the remote also) are locked to prevent them being used, there will be a method to unlock them in the owner manual
Nov 04, 2012 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Toshiba REGZA 40E200U 40 LCD TV wont turn on after it was working fine the night before.
Your TV needs servicing, Most likely you have a power supply related issue. Do you have any experience with electronics repair?
Sep 01, 2012 | Toshiba REGZA 40E200U 40" LCD TV
How do i turn the Panel lock function off on my Regza 42xv600a without the remote?
This may not be possible; it may be designed to prevent children from operating the set without an adult with the remote present.
You can probably buy an original remote or a known substitute from:
Remotes.com
Sep 10, 2011 | Toshiba REGZA 47HL167 TV
TOSHIBA REGZA 24" LCD/TV cannot
"JUST PRESS CINEMA MODE ON YOUR REMOTE CONTROL AND SELECT APPROPRATE VIEWING MODE" it might be located under the left of 0 with an image like stretching as indicated on my remote. It is the issue about the overscanning and underscanning of tv using HDMI connection. I have been the same problem as you but I did solved it using this. Hope this would help!
Mar 10, 2011 | Toshiba REGZA 47HL167 TV
I cant program any channels on my tv. Toshiba 42'' plasma. Do i need the remote or can i do it directly from the tv?
Which specific model from Toshiba do you have? There are several 42" TVs released with the Regza name. Most of the manuals can be found on the Toshiba support web site. http://www.tacp.toshiba.com/customersupport/
The one that I have allows for the channels to be set from the On-Screen Menu. In the TV mode, press Menu (there is a Menu button on the side of the TV). Navigate with the arrow keys (CH+, CH-, Vol+, Vol-) to the Setup menu and highlight Installation and press Enter (the Menu button is also the Enter key when using the buttons on the TV). Then highlight Channel Program and then Start and press Enter. When the search is done, press Ch+ or Ch- to view a station. To add or delete channels, use the Channel Add/Delete that is one line below Channel Program. Use the enter key to change the check mark status next to a channel. If adding a digital sub-channel not previously found, enter the number manually on the remote using the 100 key to add the dash. If the channel isn't found, an error message will result.
I hope this helps.
Jul 28, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba Regza tv was in storage we took it out and can't find remote is there a way to tune without it? Thanks
Yes,must use the manual control on the tv itself.Very trouble some.Buy a new exact remote on website 1-800-Remotes Factory Original.
Jan 16, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Toshiba 32AV600E 32 in. TV Logo
461 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
