Question about Toshiba Satellite L20-S310TD Notebook
Windows wont start up
Hi
the laptop will switch on and ask for the password, then a black screen appears asking which mode i want to start windows in, i choose start windows normally and then a blue screen flashes just for a second and the laptop switches off!
thanks in advance
karen
  • 749 Answers
Try choosing the SAFE MODE, this will fix some problems and if the widows screen appears at safe mode is good then restart the laptop, this will automatically go to normal mode... if so then the problem is fixed.
Post me back If this doesn't work... good luck.
It's Rommel.
Posted on Apr 09, 2008
    Genius:
  • 2,785 Answers
Dear karens25
try to boot in safe mode if the problem persist then u have to repair or reinstallyour os
Change password
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
Click "Start" icon in the lower left corner of your computer screen
Type the word "run" in the window that appears.
A second pop-up window will appear; type in the letters "cmd," then select "OK."
This will bring up the black DOS command screen.
Type next to the administrator account the following command: net(space)user(space) the username(i.e. johnadams) *. After typing this command, hit "ENTER" on your keyboard.
Type in a new password in the command screen prompt that ask you to type a password. Type the new password again once you are asked to confirm.
Type the word "Exit." This will bring you back to your login screen.
Enter the new password that you selected.
Sep 22, 2013 | Computers & Internet
Tip
When Windows XP won't start (primary fix)
Symptoms: When you start your computer, you get the black screen with a menu that tells you to start in safe mode, normal mode, etc. When you make a choice, you end up in the same place.
Solution: If you have Windows XP, you'll need an installation disk. Doesn't matter if it's yours or not. You just need a Windows XP disk. Any flavor. Put it in the CD drive and start your computer. Be sure the computer boots from the CD.
You will see the Windows installation message and the first question you will be asked is if you wish to repair Windows or install it. Choose "r" for repair. You will now be presented with a black screen that asks you which version of Windows do you wish to repair. Choose the one that is probably the first on the list--it should just say Windows. It may appear like this: C:\Windows.
You may get a second screen asking for the password. This is the password for the Administrator account. If there is not a password on this account, just hit "enter."
When you get to the C:\> prompt, type CHKDSK /P and let it run. It will most likely find errors and fix them. Once it's finished, Windows should start normally.
If it doesn't, you'll need to check out my link that addresses the "secondary fix."
on Apr 06, 2010 | Microsoft Windows XP Home Edition
Hi! I bought a new asus eb1505 4GB RAM 500G disc. I switched it on, it asked me for some settings (language, EULA etc.), I set an username and a password. Than it said it should restart. Ok. After...
What I would do is to on post pressing your PC's power on begin to click over and over till you see a screen the F8 key. Go into Safe Mode or you may be able to Start Windows Normally. If this does not work then you must either do a Recovery or Run Windows disk.
Aug 30, 2013 | ASUS EeeBox PC EB1505-B011M Intel Celeron...
Rescue password
at exactly what point does it ask for the password?
Jun 24, 2012 | ASUS X71SL-B2 Laptop
My hp mini 1000 wont boot up. when i turn it on it goes right to a screen that asks how i want to start up windows ( safe mode, safe mode with networking, safe mode with command prompts, and start windows...
hi blinkgirl556
was there a new hardware that was added to your laptop? bluescreens often are caused by hardware.
while the laptop is booting up when you are asked for options on how to start you computer is there an option for start windows using last known configuration? if there is try that and if it still goes into bluescreen you may want to try and recover your laptop using the hp recovery cd or recovery tool. if it still doesn't work most likely you have a bad memory chip.
hope this helps
contact me for any updates
janc30
Feb 08, 2011 | HP Mini 1000 Netbook
My A30 ibm laptop wont start up??
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 03, 2010 | IBM ThinkPad A30 2652 Notebook
My laptop wont let me in i bought it at this yard sale when i turn the power on it ask me for passord i dont know it what cai do.
Depends when it asks for P/W is in the black n white screen or logon to windows.
Boot into safe mode and negotiate to passwords in control panel, remove password.(If in windows logon P/W)
If its at boot up in bios then its a complete dismantle of the laptop to remove the cmos battery for 1 hour.
Feb 24, 2010 | Dell XPS M1330 Laptop
My dell vostro 1510 asks for HDD password. When i give it,a black screen comes and asks to choose from following a)start windows safe mode b)start windows normally and so on... After entering choice XP...
Oh boy, you need to call dell for that. the hdd is locked and only dell can give you the password. dont try unknow passwords its not gonna work. the password is related to the secuity of the machine. call dell and they will give you the password. in case by any reason you cant call dell. you need to repalce the hdd then. call dell they will give you the password free.
Oct 02, 2009 | Dell Vostro 1510 Laptop
My HP Compaq d530 SFF Wont Startup
Use the Last known good configuration from the safemode menu
Aug 04, 2009 | Computers & Internet
COMPUTER WANTS PASSWORD, THERE ISN'T ONE
TRY TO OPEN YOUR SYSTEM IN SAFE MODE
FROM THERE YOU CAN RESET YOUR PASSWORD IF ANY.
PRESS F8 WHEN BIOS SCREEN APPEAR WHEN YOU STARTS YOUR SYSTEM.
Apr 22, 2009 | Toshiba Satellite A135-S2386 Notebook...
Toshiba Satellite L20-S310TD Notebook Logo
140 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
