Question about Samsung Televison & Video
Samsung ln52a650 Hello samsung gurus, I recently had to replace my tcon board on my tv, because it went on me. But now i also need a new ribbon cable that connect from the tcon board to the lcd screen. Their are four of these cables they are about 3 or 4 inches long, one of them went bad when replacing the board, now i have a colored strip in the middle of the tv. does anyone know where i can order these or have a part number of this cable. Thnaks Derek
  • wiech101 Jun 03, 2010
    Hey James,
    Thanks for the reply this cable is not the one i am looking for. The LVDS cable connnect the tcon tot he input main board. I am looking for the four small ribbon cables that connect from the top of the tcon the lcd screen. These cables are what send the the information from the tcon to the lcd screen
  • 91 Answers
This is called the LVDS cable.........try Encompass parts.com they are samsung distributor........shopjimmy.com has salvaged sets where you can buy the cables and ribbons for a given model as a set
Posted on Jun 02, 2010
  • James DuPont Jr
    James DuPont Jr Jun 03, 2010
    Ok,I see.......these are actually only included with a new panel the ribbons and tcon come with it. Since shopjimmy.com salvages the sets........call them and see if they will steal them off a broken screen for you!!
Hello new to this but they told me to try my luck here. I have a Samsung 32"LCD tv model# ln32d450g1d it's just recently gave me this problem where half or more then half the screen the colors are not...
Unfortunately this sounds like a panel board issue, most sets have a Tcon board that is separate from the panel board however yours is built in, try cleaning the ribbon connectors that go to the panel but I don't think that will help and to replace the panel would cost more than the set is worth, you may be in the market for a new tv unfortunately
Apr 17, 2018 | Samsung Televison & Video
Samsung tv has vertical lines and washed out appearance why
OMG..why so many bad answers on here all a sudden ...Chances are you have a bad Tcon board or its possible it could be the main as well however tcons fail way more than main boards with your issue, vertical lines means bad tcon, horizontal can mean a bad display...I can count on one hand the times Ive had a bad display with vertical lines and Ive serviced thousands of HD TV's over the years...but what I want you to do 1st is remove the LVDS cable that goes from the main board to the tcon board, clean the contacts and replace it...then do the same to the two flat panel ribbons that go from the tcon board to the panel, its not real common but on occasion they will loose connection and give vertical lines, don't want you to buy a board if cleaning the cable connections will help...just use a little rubbing alcohol to clean them...Good luck, if you need more help feel free to message me back.
Mar 26, 2018 | Samsung Televison & Video
Anyone know what board/s I may need to fix my Samsung HP-S4253??? I'm getting horizontal lines. Other than that tv works and looks good.
Its a little hard to tell by the picture but aren't those vertical lines, going up and down?...if so replace the tcon board or try cleaning the LVDS and ribbon cables in and out of it and see if that helps first
Feb 05, 2018 | Samsung Televison & Video
How do I fix my Samsung Tv.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 19, 2016 | Samsung Televison & Video
Need to know if T-Con board needs replacement for my Samsung LCD TV?
Hi Michael,
Before replacing it, please check and thoroughly clean the flat ribbon cables to and from Tcon board. It may help. It is a delicate job and requires all the care. You may watch some Youtube videos about how to do it.
Aug 13, 2015 | Samsung Televison & Video
Need solution for Samsung 39EH5003, Has sound but no picture
if the inverter board for backlight get to work so the cause either your lcd panel get malfunction or the t- con board doesn't work.
Jun 15, 2014 | Samsung Televison & Video
Samsung ln46a650 - reseating lvds cable
Many tv repair tried to replace t-con to fix.it's well known by now that those lcd panels in those models fail in the way you are describing.You need new panel.I have changed panel in that model before with a Toshiba 46" lcd panel and it's t-con.Your models panel is mounted upside down (t-con at bottom) Toshiba is at top like most.I don't recommend you try this.must know what you are doing. Good luck
Mar 14, 2014 | Samsung Televison & Video
Samsung LN52A650 lcd will not turn on after power
open it up / there should be a glass fuse replace it/ull find it were the mains lead goes on the board/also try new lead just incase
Dec 26, 2009 | Samsung LN52A650A LCD TV
Televison & Video Logo
673 people viewed this question
Jerry Greenberg
Jerry Greenberg
