Question about HP OfficeJet 6110 All-In-One InkJet Printer
Scanner error when powering up printer - I have previously cleaned the glass (both sides) as well as cleaned and lubricated the rod on which scanner rides on, this originally solved problem for a couple of months now same issue is intermitten, additionally when I am able to get printer to power up without scanner error, I have to push the copy button in order to print from laptop, any suggestions? buy another printer?
  • jruben Jun 03, 2010
    thanks
    Top Expert:
  • HP Master
  • 76,164 Answers
You have a problem with the control circuit board inside the unit, I advise customers that repairing these is really not the wise thing to do, a good quality all in one goes for less than $100.00, many are less than $50.00, they make there money off the ink cartridges not the all in one, i just bought a Canon MP490 that was free after rebate, it is a really excellent machine, the average repair cost is over $100, so money wise just replace it.
Posted on Jun 02, 2010
Canon MF4450 error code E202-00020
this error means you scanner is not going back to starting position which is the left side of the glass flat bed.
Try Restarting it a few times. If not try this.
Open your scanner and clean & lubricate rail.
  • Turn Off the Printer
  • Loosen the screws before you open Scanner
  • Clean glass lamp
  • Clean and Lubricate the rail.
  • It might also be off alignment try to gentle move it back to starting position. (be careful, you may strip something)
  • If you still get the error once you turn it back on then your sensor might be broken.
Apr 26, 2017 | Canon Office Equipment & Supplies
Please I Need A Solution To Sharp AR-M ( L1-00 Code )
Scanner movement error--
Remove the glass if you are a technician and clean the scanner rail on all sides. The rail can rotate for complete cleaning. Lubricate the rail with 4 or 5 drops of oil. It takes very little friction to stall the scanner. Or call a tech to do it for you. Unplug copier prior to doing this as the scanner may still have voltage even with power switch off.
Sep 06, 2012 | Office Equipment & Supplies
Scanner grinds when powers on
Its not drivers issue, hard ware issue.. Scanner assm faulty,replace it..For tech guys:Open flat bed glass, remove scanner assm clean inside reflector glass with ear buds & adf glass especially at home position.. lubricate on rail refix it back.. check it..
Dec 22, 2011 | HP Photosmart C4580 All-in-One InkJet...
Error l100
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Jan 12, 2011 | Sharp AL-1651CS All-In-One Laser Printer
Scanner won't move, just clicks
I had the same problem. I just followed the solution here:
http://www.fixya.com/support/t6219664-hp_6110
for "scanner failure". there are instructions on how to remove the document feeder and scanner glass, clean the glass and lubricate the rod that the scanner travels on. I followed the procedure and my printer/scanner now works fine.
Nov 27, 2010 | HP OfficeJet 6110 All-In-One InkJet...
ERROR L1-00 EN SHARP AL1661CS
Sep 03, 2010 | Sharp AL-1661CS All-In-One Laser Printer
Scanner error on display Power On Off
open the top side of the scanner and clean inside of the glass you will see a white line behind the glass, clean it and try agan this is a standard problem of HP 6110 type all in one printers
Jun 26, 2008 | HP LaserJet 3030 All-In-One Printer
Lexmark X422MFP Error 944
Removed CCD ribbon cable, cleaned edge connector and re-connected. Working well so far.
Jun 24, 2008 | Lexmark X422 All-In-One Laser Printer
Yellow line showing on in scanned pages
if you can open the cover of the scanner just clean the glass and use any lubricant to apply on head rod to move smoother .
bye
Nov 14, 2007 | HP 9200C Digital Sender
Unit wont start up after power failure
Answer on fixyourownprinter.com. Search there to see how to lubricate rod under scanner glass. Common fault. Mine responded instantly starting up fine after rod lubrication which stops scanner initialisation routine and leaves you looking at hourglass.
Jul 30, 2006 | HP PSC 2510 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
