Question about Maytag Washing Machines
Maytag washer,model #LA412, smokes & smells like burning rubber. It wont agitate properly but it will spin & drain. The motor is on a spring, so I cant tighten the belt. It also makes a strange noise while trying to agitate.
  • 1314 Answers
SOURCE: washing machine smells like burning rubber!
sounds like you have a broken motor coupling while your down to the pump check for something jamming the pump here is the procedure First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
Posted on Jan 20, 2008
rickzilla
  • 706 Answers
SOURCE: smoke coming from back of
You may have overloaded the washer and the belt drive system could not handle that excess mass.. The smoke and burning smell is a belt melting while trying to rotate the drum.. I would unload it .. gain access to the drive mechanism ( probably via an access panel in the back but may not be.. - brand and model specific).. and then check for damage to the drive belt.. You may look at the pulley system and look for burnt black from melted belt on it.. You could also have a clog in your pump that the belt drives but can't ( because of that clog) and therefore the belt rubs over the pump pulley and melts.. Could be any one of those things.. Hope that helps..
Posted on Aug 24, 2008
  • 3 Answers
SOURCE: Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
Posted on Oct 01, 2008
huuum
  • 750 Answers
SOURCE: smoking burning rubber smell from machine
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Posted on Oct 06, 2008
  • 42 Answers
SOURCE: burning rubber smell
Even though manufacturers' love to advertise it, I personally would not load "too many items", as it may cause excessive normal ware and tear on your machine parts, motor, belt, etc.
Yes; the smell can be the belt and possibly your motor as well. The motor may be spinning, but the weight may be too much when the belt is engaging to rotate the drum. I would be careful not to burn the motor (About $120 - part only)
You should be able to access and inspect the drive-belt in the rear of the machine by removing an access panel (back of washer).
To replace the belt if fairly simple. Remove and re-install by wedging a long screw driver in between the belt and metal pulley (circular), while simultaneously rotating the pulley.
You may be required to make a belt repair if you start to have problems with your "washer not spinning" or "making a noise/not spinning"
Posted on Jan 26, 2009
Smoke come in out while spinning
Don't know what machine you have if it has a belt check it. Take belt off & see the motor turns freely also with the belt off see if you can turn the drum if one of them won't turn the belt will slip & cause burning smell. Small clothes getting under the agitator even sometimes in the pump can cause this , check under agitator & check the pump it may not turn if a sock or something gets in it & this can cause the belt to slip. If these seem ok put it in spin & watch the motor it could have a short & will smoke. Good luck
hope this helps.
Nov 22, 2017 | Washing Machines
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
We have a MMDE9206AYM model dryer that makes a low humming sound but will not start. Last night it also produced a burning smell. I assume either the belt is gone or the motor is overheating although it...
Sounds like drum is locked and motor is running and burned the belt. Try to spin drum by hand, Might check drum ends felt seals, Teflon bearing strips located on the bottom lip of front drum end for wear causing drag. Also check 2 drum support wheels to see if they spin freely, take the belt off motor pulley and spin drum by hand, if easier & motor runs drum is dragging. How is the spring on tensioner, does tensioner pulley spin free? Hope this helps locate the problem.
Feb 13, 2011 | Maytag Dryers
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Tub not spinning smell rubber
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Some part of the motor burned out that's why you can smell burning rubber. Check some faulty parts.
Mar 28, 2010 | Maytag Washing Machines
I have a frigidaire washer model fws777ghs0.after the spin cycle the water is drained but the clothes are too wet.there is a smell of burning rubber.when I open the lid I could see a slight smoke.could it...
probably burned up your motor coupling! see if you can hear the motor running either on the agitate or spin cycle,if you hear the motor running but no movement then it's gonna be the motor coupling it's plastic and rubber! cost about $20
Jan 11, 2010 | Washing Machines
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
299 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
