Question about HP L1925 19" LCD Monitor
How to rotate display vertically on HP L1925 - HP L1925 19" LCD Monitor
  • qwertqwert
    qwertqwert Jun 02, 2010
    If this doesn't work or is unclear please tell me which version of Windows you are running. The ability to rotate the monitor image through software (I assume that is what you are asking) is entirely dependent on which kind of graphics card you have because it is a feature of your graphics driver. Or to put it another way: Hold down Alt and Ctrl and push the arrow keys. This will flip the image different directions, only with Intel integrated graphics. If this does not work you most likely have ATI, nVidia or some other form of graphics chipset. You can find the same functionality in the respective driver software. This will vary by graphics driver software and version of Windows. If you can tell me your graphics card and Windows version I can help you further.
    President:
  • 1,194 Answers
Press control alt arrow key (up or down to rotate vertically and right or left to rotate horizontally) simultaneously to rotate the screen.
Good Luck and have a nice day
Posted on Jun 02, 2010
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Feb 15, 2013 | Samsung N120-12GW Netbook
Need to fix rotating screen back to horizontal!
I think you are referring to the picture on the laptop screen has rotated away from landscape or upside down. If this is the case, right click on the desktop away from icons and scroll down to "Nvidia or ATI control Panel", when this window opens look to the left and you will see a refrence to "Screen Orientation", click the drop down menu and select "Landscape". If you do not have the "control Panel" option, go to the bottom and choose "Properties", then display settings, then advanced settings, look for screen orientation, and choose landscape.
Aug 01, 2010 | HP Pavilion tx1000z Notebook
What is the model of chopper transformer of HP l1925 monitor
It depends on who made the board, you can have more than one version of the board for the same model number, HP does not make the monitors, they get from the one who can make the cheapest one, you need to get inside and get the number, then google it or try here: http://www.lcdparts.net
Apr 12, 2010 | HP L1925 19" LCD Monitor
Have a Hp L1925 lcd monitor that the green power led light comes on but the screen is black. Used a flashlight and can see the logo and windows start.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
I have several HP L1955 and L1925 monitors do not show image
michael_b173, You will need to do some extensive reading in my fixya profile and pay a visit to the following web site:
http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ ALL "cold-cathode-fluorescent-lamp" back-lit LCD monitors are the same in their basic design and operation!!!! Follow the other links you find in my fixya profile responses to other "black" or "blank n black" screen lcd monitor owners to make decision if DIY repair is option for you. Two other fixya lcd monitor tech's (buddymc and budmrtn) are also helpful. Read their stuff also!!! They also have "how-to" and lots of photos of what to look for inside monitors.
Good luck with the repairs. 12fixlouie
Mar 25, 2010 | HP L1955 19" LCD Monitor
I have a Silicon Image 164 ADD DVI card added to my HP desktop DVI-D access card in an effort to get a dual monitor configuration. I get an exact clone in the second monitor. I have an HP compaq desktop...
If the Intel graphic card is part of the motherboard, you need to disable this in the BIOS. You need to install the Silicon grpahic driver, then you will be able to configure the screen resolution etc for each monitor.
Jun 10, 2009 | HP Compaq d530 CMT PC Desktop
Change from landscape to portrait
There should be an option either in the monitors drivers or in Windows Control Panel that sets it to portrait mode. I hope this helps, Yannick.
Jun 06, 2009 | HP L1925 19" LCD Monitor
Hp vertical monitor help plz....
after looking over the spacifics of the model you posted, I'm not certain that you are correct in assuming this monitor is meant to be viewed virtically. The issue is the monitor's resolution. Typicaly, your monitor's resolution dictates it's orientation. for your model:
Recommended resolution (H x V) 1680 x 1050 @ 60 Hz
that means your monitor is not meant to be virtical. However...
If you indeed wish to tilt your monitor on it's side, depending on your graphics card, you may be able to use proprietary software to " rotate " the display.
(nVidia has settings such as these for some of thier graphics cards. )
Model Information Source(s):
http://h10025.www1.hp.com/ewfrf/wc/useCategory?lc=en&cc=us&product=3543988&dlc=en
May 29, 2009 | HP W2207H 22 Notebook
How do I rotate the screen when I rotate the Acer B203w
For Windows XP -- within the control panel, click on Display Icon and the following screen will appear. I have 2 monitors (Laptop and HP L1925 monitor). On the display properties screen, near the top of the screen, click on the “Settings” tab. When the “Settings” screen displays, select the “Advanced” button near the bottom of the screen.
The “Plug and Play Monitor …” screen will appear as shown below. From this screen, click on the “INTEL(R) Graphics Media Accelerator Driver for Mobile” tab near the top of the screen. Note: Tab stretches the full width of the screen.
The "Plug and Play Monitor ..." screen will change to show Intel Graphis Media Screen. From this screen click on the “Graphics Properties” button near the center of the screen.
The screen will change to show the graphics properties. Note, the screen actually comes up with “DISPLAY SETTING” selection (in dark Blue on the Left hand side of screen). To change Display settings click on the words “DISPLAY SETTINGS” (left side of screen) and the screen will switch to show Rotation options. On the top of the screen, select the “Monitor” you wish to change by clicking on “Monitor” button. Next make sure the “Enable Rotation” box is check on the right side of screen and then click on “90”. Your monitor should rotate at this point to portrait. A message will appear letting you confirm if you wish to keep this new setting. Specify yes to keep the new setting.
This should do the trick.
Joe Buus
Jan 29, 2009 | Computers & Internet
Full screen on monitor
you can use the menu and adjust the vertical size.or if did already but it doesn't work,try to open your monitor and look for a trimmer in the vertical section,then try to rotate by these you can adjust now the vertical size
Oct 18, 2007 | HP Compaq FS7600 17" CRT Monitor
HP L1925 19" LCD Monitor Logo
311 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
