Question about Alpine MRP-T220 Car Audio Amplifier
It cuts off
I turn da volume up n cuts da base off n its bridged
    Problem Solver:
  • 19 Answers
Amp maybe can't take the load ur puttin on it
Posted on Jun 06, 2010
Choke needs 2 be up when driving motorbike, is dat bad for da bike?
A choke reduces the air flow to make the mixture rich. Unless the mixture is too lean because of fuel issues.
Apr 10, 2015 | 1994 Yamaha XJR 400
Kako da udjem na fb,pise da mi je netacna imejl adresa
Savjetujem ti da nadjes uredjaj kojim ides na internet i da ga resetujes (iskljuci iz struje i ponovo ukljuci) mozda na taj nacin resetujes postavke istog! Detaljnije opisi problem, mozda se nadje neko rjesenje!
May 31, 2011 | Computers & Internet
I know what the problem is I just want to know how to fix it. Last nite I had three subs on 1 side bridged blasting being careless, on my way home da subs cut off, da protection lite came on but my highs...
if its been smoking you have internal component damage and it will need to be exchanged returned or you will need a technician with electrical experience soldering tools and an exploded diagram or the unit we can get you the diagram and user manual but the tech would most likely be found at a car stereo installation center
Robb
Sep 24, 2010 | Pyle PLAM3000 Car Amp
When i cut the volume up on my radio or turn the bass up the amp cuts off and on
check all wires .... make sure your speaker wires arent in the wrong order or shorting ...
did this just start of was it always going on ... if it just started its probly a short in the wires
Feb 10, 2010 | Rockford Fosgate Punch P5002 Car Audio...
When i turn on my lights @ nite da car cuts off
If turning head lights on makes the car die,then the alternator is bad.Replace the alternator,and have the battery charged with a slow 2 amp charge,this should get you going.If I can help,let me know.
Aug 27, 2009 | 1991 Pontiac Bonneville
Hay i just brought da sub on its own and dont no wat a good size amp and power needed to make dat bumpn bumpn feel...and how to connect it all up plezzzz.... fnx DJ KINGXL out
buy a bridged amp with half the power of your sub (ie 1200 watt sub use a 600 watt amp) this will stop distortion at high volume get in touch when you have the amp and i'll go through how to wire it .
Aug 20, 2009 | MA Audio MA 1200XL Car Subwoofer
When i turn up the volume the base cuts out and
Check and re check the grounds. You need a good solid ground. Sound simple, but we always seem to overlook the obvious... or Possibly the deck has a high output(rms watts) and is overpowering the inputs on the amp. In this case use a line out converter.
Jun 28, 2009 | Fusion FEW12PK Car Subwoofer
Subs cut out at low volume no matter the settings
I'm not a complete audio expert but it sounds like somethings over heating or you have a blown out put bridge.
Jun 20, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Amp turns off
You did not specify the model you have - however the Flex series is only stable with a load of 4 ohm mono (bridged) and 2 ohm (stereo).
You are driving the amplifier to work too hard, and it is shutting itself down.
Re-wire using one subwoofer (bridged) or wiring the subwoofers on seperate channels.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 08, 2009 | Car Audio & Video
SUBS
Hi , you need to replace with thick wire , if possible attache fuse or circuit trip overload protection you may ask to thew radio store .
May 07, 2008 | Polk Audio EX12 Car Speaker
Alpine MRP-T220 Car Audio Amplifier Logo
61 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
