Question about Fisher Price Long Distance 900mhz Baby Monitor
Constant hum without any noise in room where base unit is located, I have tried changing channels but humming continues
  • jruben Jun 02, 2010
    i would rather not buy another unit (a digital unit as suggested)
    thanks for the insight, we did some relocating of remote phones it seems to help issue, thanks again
  • 3,083 Answers
Unfortunately, the humming is one of the characteristics is this monitor. Read this blog on the monitor, and it will explain why (interference, background noise, etc.) http://babyproducts.about.com/od/recallsandsafety/gr/fisher_price_900_mHz_long_distance_baby_monitor.htm
Apparantly, the monitor will not work in some homes without the humming (a pretty common complaint of the device). There seems to be no remedy, since it's an environmental interference, and since the unit is analog, it is susceptible to noise, thereby creating a humming sound.
The microphone sensitivity also contributes to the problem. Here's an excert from the review explaining this:
The fairly sensitive microphone plus the analog signal mean that this baby monitor will probably transmit a constant, low hum of background noise and quiet static. This is a common problem with analog baby monitors, though. The low noises that come from the Fisher Price 900 mHz Long Distance baby monitor are not worse than other comparable baby monitors. The noise also does not drown out any baby sounds, so you should still be able to hear your baby quite well. If you want the monitor to be totally silent between baby's cries, though, you'll need to spring for a digital baby monitor.
Sorry to have to report the bad news, but the noise seems to be an inherent problem, mostly due to the analog design. The "fix" to this problem, what what they say, is to purchase a digital monitor. They are more immune to noise, humming, etc. Hope this answers your question, and again, sorry it's not a solution to the problem you're having.
Posted on Jun 02, 2010
  • 344 Answers
Sorry but this is the nature of most analogue baby monitors, they are very prone to picking up stray signals hence the hum, there are some available that switch off until an actual noise is detected but if you really want one that would do away with this hum altogether I would suggest you buy a digital (DECT) monitor.
Another point worth mentioning is analogue signals are not secure or encrypted like digital so anybody nearby can listen in to your frequency if they have a similar receiver
Hope this helps
  • Tony Groves
    Tony Groves Jun 02, 2010
    You could always turn the volume down slightly!
  • Tony Groves
    Sorry please disregard the volume comment, I was refering to receiver and not base unit
Device is making a whistling sound or humming sound. It still has power and is powering the devices plugged into the back up system.
Is the unit running on battery power? A hum is normal when the inverter is running.
if it is CONSTANTLY making a humming noise, it is possible the unit is failing. Check your battery inside the unit, make sure it does not look swollen at all. If it is, you know the unit is failing and overcharging the battery. If it is not, pull the power cable from the outlet and see if it provides back up power and then plug it back in.
If the connected equipment stays on line, then the unit is working fine however I would consider buying a replacement UPS in the near future, a constant hum all the time is a bad sign.
Mar 10, 2010 | APC BE325 SURGE PROTECTOR + BATTERY...
"humming" noise after tire replacement
check the wheel bearing sounds like a problem there.
Jan 11, 2010 | 2004 Lexus GX 470
Humming and buzzing
You're getting electrical interference, probably near the base unit since you hear it on all the phones. Try moving the base unit to the other side of the desk (away from say a clock or radio), or check where your phone wire going to the base unit is running. It may be laying on top of an electrical cord or going across some other electrical device that has a motor.
Jun 02, 2009 | Panasonic KX-TG1033S Cordless Phone
Constant hum when the computers are connected
Hums come from several sources. A light dimmer switch on the wall. Speakers too close to a monitor or other electrical device. Try turning off everything in the room or nearby rooms, one at a time while the hum is audible.
Apr 15, 2009 | Bose Companion II Computer Speakers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
My Motorola MA580 sometimes work and others don´t
It sounds as if the channel that the phone and base has selected during that session is bad, or being used by another system in the area. When that happens, try selecting another channel. You should be able to do this by depressing a button on the handset. Normally labeled "Channel". Please post further questions or comments. Please rate this solution through fix-it. Thank you
Jun 28, 2007 | Motorola Mobility MA580 (612572111116)...
Audio technica at 4040 constant ground hum noise
you can test the cable from connection to connection for continuity from end to end. There should be no resistance( a complete short) If the cable is good, there is a bad or broken connection inside the mic. Good Luck
Jun 23, 2007 | Audio Technica Audio-Technica AT4040...
Fisher Price Long Distance 900mhz Baby Monitor Logo
766 people viewed this question
Top Fisher Price Baby Gear Experts
romney2012
Lyle Siemens
Lyle Siemens
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
