Question about Kenmore Elite 45986 Front Load Washer
How to fix fh error on a kenmore elite he3
I need a diagram of where the little screen that i need to clean is.
  • 15,935 Answers
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
SOURCE:
My Opel Corsa 17 dti wont start, Check the injectors (Dry) Replaced the Diesel filter, fill it with diesel and try to start with no success. Try to bleed at the injectors(Completely dry)
There's this website www.reliable-store.com
They have books
on ALL vehicles.
it covers wiring diagrams, electrical diagrams, fuse diagram, torque specs, PCV, error codes, fault codes, service info, repair info, parts info, owner's/service/repair/parts/maintenance manuals etc everything totally..
I have 1987 toyota 4runner model and I keep servicing and when needed repair it on my own. worth it !!!
Mar 18, 2018 | Opel Cars & Trucks
Sony VAio touchscreen hypersensitivity
Step 1:
Touch screen monitors are both input and output device as they receive and display information from one peripheral device the monitor screen without the use of mouse or keyboard. They are used in a variety of different applications such as point of sale (POS), cash registers, ATM machines, among others. Touch screen monitors are very sensitive so proper cleaning and maintenance is of utmost importance to maximize its performance and prolong its life. Follow these cleaning steps:
Turn off both the computer and touch screen. This way, you can see everything that needs to be cleaned. Some touch screen applications has a cleaning mode which turns off the screen for the specific purpose of cleaning. However, the monitor's brightness can make you miss some areas. Wet a soft, lint-free or microfiber cloth with distilled water. Wring out as much water as you can. Make sure the cloth is damp but not wet. Wipe the screen in a gentle motion to remove dust, oil, or fingerprint smudges off. Another option is to use a screen cleaner kit that includes antistatic wipes. You can buy this at various electronic or online stores. Spray a little solution on a wipe then rub it gently across the screen. Finish cleaning the touch screen with a dry lint-free cloth to wipe any excess moisture, then turn it back on.
Feb 23, 2013 | Sony VAIO Computers & Internet
How do i clean the screen on a panasonic pt-50lc13
I am attaching the diagram that shows how to remove the screen. Its not very big but I can email the full size diagram if it would help.12_24_2011_5_47_56_pm.jpg
Dec 24, 2011 | Panasonic PT-52LCX65 44" HDTV
When on cold/cold very little cold water is coming in to washer. I checked the hose and cleaned the screen. If I do not turn off the hot water I get nothing but hot water no cold.
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/topwaterinletvideo.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Jul 05, 2010 | Washing Machines
Very little water coming out
clean group,move screen and screen holder and you see small piece in head,unscrew that and clean group with wire but be carefull machine need to be cold when doing that
Aug 05, 2009 | Gaggia Baby Espresso Machine
My screen on my sidekick slide wont slide smoothly
ur bolts are loose u will need to get it fix and u will need to not flip it alot that is wat causes it
Apr 29, 2009 | T-Mobile Sidekick® 3 Cellular Phone
I have a panasonic PT 44LCX65 44" LCD rear projection TV. How do i disassemble the TV so i can clean the inside of the screen. Also i noticed on the projector lense a huge tumb print on it. not the...
I would recommend getting a service manual as the light engines are a little complicated to get out. where the manual would have an exploded diagram which would make it alot easier. If you need a link to get the manual let me know and I will post one for you.
May 03, 2008 | Televison & Video
Strange Screen Issue....
Youscreen need to be demagnetised.
Sep 10, 2007 | Sony KV-32S26 32" TV
Kenmore Elite 45986 Front Load Washer Logo
90 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
