SOURCE: Water runs out of the bottom of the washer as
Check the pump assembly ( this is a common pump ) first for a leaking problem, check fill valve, hoses, and center seal under the outer tank in the middle where the transmission goes inside the washer. The button catcher ( on older style washer ) on the side of the outer tank is also bad for leaking. See #'s 16, 17, 18 for the button catcher, grommet and clamp. Replace them all at the same time, the grommet is glued as well as clipped into the outer tank. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
Changing a pump tips: This pump is pressed onto the motor shaft. The motor shaft often starts to rust and the shaft swells out and holds onto the pump...tightly!! Often need to...remove power, remove the pump clips, remove the hoses from the pump assy. if the pump assy will not lift off of the motor shaft, you may need to remove the motor & pump together and break off the pump assy. A hammer and flat screwdriver can usually crack the old pump so it can be replaced. Sand/clean the motor shaft before installing the new pump.
How to fix a Samsung Washernd washer error code. You can make this repair your self and in most cases without parts. Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain. When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front. If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise. If the front panel does not have the access panel the washer will need to be slide forward. With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible. Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
