Question about Ridgid 10"Wet Tile Saw with Laser and Stand
7" rigid tile saw
The motor bound and stopped working. Is there a reset button,? what are my potions?
4 Suggested Answers
  • 32 Answers
SOURCE: how do you square the rigid tile saw to cut
take a framing square and set it aginst the back stop.
then loosen the screws that hole the saws arm to the base.
now set the square aginst the blade and adjust untill it is even,in the front and the back.once you have acheved this tighted the screws on the arm to hold .
Posted on Nov 06, 2009
  • 4088 Answers
SOURCE: where do i find a gfi for my tile saw? it stopped
You usually don't install gfi's at the load (saw) but instead at a socket where the plug is inserted. If you use an extension cord, change the socket end to a metal 'handy' outlet box and install a local type gfi there. Wire the black wire to the brass screw, the white wire to the silver screw, and green wire to the green screw. Make sure that none of the wire strands are left loose to short out on something. They are available in any hardware store or home center. Hope this helps!
Posted on Mar 19, 2010
SOURCE: ridgid tile saw wts
I cut mine off!! then put a normal plug on it. Works great.
Posted on Oct 23, 2010
Does the rigid wts2000l tile saw power supply cord have a fuse in it
NO
the fuse will be in the breaker.
the cord could be broken internally or at the plug or motor
Jan 27, 2017 | Saws
Rigid tile saw. Can I use a wood blade?
Tile saws are designed to use a diamond blade, and to keep it wet. That's not something you want with a wood blade, nor with wood. The speed of a tile saw is much slower than a good wood saw. I wouldn't try it.
May 27, 2015 | Blade Saws
Need a pushbutton off/on switch for toyang tile saw motor
Hi, you can purchase push buttons on amazon, click here and take a look: Amazon com Tile Saw switc. I hope this was helpful. Cheers
Aug 15, 2012 | Delta Saws
Tile saw wont start. It's brand new. Is there some sort of safety device.
The first thing you should check is the GFCI switch on the power cord. All tile saws have one because of the water involved with cutting tile. It should have a test and reset button on it, press the reset button to get power to the saw motor. Some bigger saws also have a reset button on the motor itself for overload issues. Check for that if the GFCI reset doesn't work.
Jun 02, 2012 | Saws
My MK370 tile saw has a burning smell and it is making a slight banging noise every 7-9 seconds. The saw is cutting tile fine otherwise.
The problem could be bad brushes. Otherwise, you are probably burning the windings inside your motor. The slight banding noise could be an issue with the bearings in the motor itself. In which case you will soon be replacing the motor, so... we'll hope the brushes prove bad.
Assuming the motor has brushes, there will be 2 semi-large buttons on the motor (one on each side). They are screws. Remove them and beneath each one is a "brush". They should be long, hard, crack free, and smooth on the bottom where they touch the rotor. If not, then replace them. Almost all motors used for tools have brushes and some motors require disassembly of the motor itself to replace the brushes, but in your case, it should be an easy job. I can see one of the buttons on the Amazon picture.
:o)
Jun 03, 2011 | Mk Diamond 159943 MK370K 114Horsepower...
Cannot keep water on the blade of my 10" Rigid wet
if waters not getting to the blade you will see the powder of what ever your cutting coming off the back of machine,i like to put my pump in a bucket of water under the drain plug instead of puting the pump in the water tray,you can run bigger tubing up to the blade and reduce it down and it will give you better presure,good luck
Dec 31, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
The arm that holds the motor to the tray, broke and cant find any replacement part, why is that?
Go to the Rigid web site and get their coustmer number they have replacement parts there.http://www.ridgid.com/ Shows you saw and parts for it.
Nov 11, 2009 | Ridgid 10"Wet Tile Saw with Laser and...
Need to purchase replacement part for a wts200l rigid tile saw
TILE SAW WTS2000L ;THE UNIVERSAL GUIDE CATALOG NUMBER #:6006001.I NEED TO BUY ONE
Mar 11, 2009 | Saws
Water flows for cooling but saw does not rotate
check to see if the motor has overload reset button on it (red) usually the water is only pump portion of circuit and can run independent of motor circuit , if not check wiring to motor circuit
Nov 20, 2008 | Mk Diamond MK - 770EXP
Tile saw stopped working
check the motor might have a reset botton or check the capacitor
May 31, 2008 | Dewalt DW746X 10" woodworker's table saw...
Ridgid 10"Wet Tile Saw with Laser and Stand Logo
106 people viewed this question
Top Ridgid Saws Experts
ken skalski
John Trevino
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
